Ok here's the inbox review of the TU144 in 1/72 the first thing is the size of the box which could be almost half the size it is when you see all the space inside
Anyway you get a large bag of sprues and a separate section for the wing section and fuselage a 20 page instruction manual a large transfer / decal sheet and 2 small sheets with flag and interior cockpit instruments panels whether it's worth £250.00 is debatable but that's the going rate as it has to be imported from Russia / Ukraine expensive cockup if it goes wrong the mouldings look crisp with no sign of flash so it should go together relatively cleanly there are several variations during the construction such as nose down with canards extended and undercarriage or clean version with wheels up and canards retracted also one version had slightly different wing tips to the other which is included with this kit
Finally there's 2 full colour 3 way diagrams showing decal placement and exterior painting colour depending on which version you pick
[ATTACH]114682.IPB[/ATTACH]
[ATTACH]114683.IPB[/ATTACH]
[ATTACH]114684.IPB[/ATTACH]
[ATTACH]114685.IPB[/ATTACH]
[ATTACH]114686.IPB[/ATTACH]
[ATTACH]114687.IPB[/ATTACH]
[ATTACH]114688.IPB[/ATTACH]
[ATTACH]114689.IPB[/ATTACH]
[ATTACH]114690.IPB[/ATTACH]
[ATTACH]114691.IPB[/ATTACH]
