I have just ordered one any advice on how good they are would be welcome [ATTACH]114971.IPB[/ATTACH]
Kitech Blue thunder
Tags: None
I don't recommend parking it on railroad crossings!On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4.Comment
Kitech is one manufacturer of model kits I avoid. Having said that peter, a quick check online shows this is in fact highly likely a direct Monogram rip off so you might be okay with it. A write up on the 'Blue Thunder' kits here: http://scalemodelingdomain.blogspot.co.nz/2015/01/blue-thunder-movie-and-her-132-scale.htmlComment
Kitech is a manufacturer that I also avoid. I picked up an Aardvark in 1/48 from them and it was literally s**t. Keep dry fitting, but if you manage to get some good results, I will be greatly impressed
JohnComment
