Spitfire Mk 9 Propellor - material ?
  • colin m
    • 8741
    • Colin
    • Stafford, UK
    What is a mk 9 spitfire propeller made out of ?
    I've found some information on line which says that a blade has both a covering and a sheath, but I'm not sure what the final layer would be.
    The 1:32 Tamiya Spitfire has the red/pink disc markers on the blades which means the sheath would be either brass or steel. But I can't imagine, the laminated blades would then be covered in either steel or brass.
    So I'm thinking, very simply that the blades are made out of laminated wood (Jablo wood - a laminating/impregnation process) and so can't be weathered using a chipping effect to show 'metal' underneath. Any ideas anyone ?
  • PhilJ
    • May 2015
    • 1145
    I think it probably would have been a Jablo wood type, I think if you have a search that different colours on the prop indicate certain wood types. Maybe check the decals?
    Would be interesting to see what you find out.
    • colin m
      • 8741
      • Colin
      • Stafford, UK
      It almost certainly is wood. There's a few pic around of crashed mk9's. But what I just don't know is if they were somehow covered in a thin veneer of metal - which I can't see myself.
      • stona
        • Jul 2008
        • 9889
        The disc colour did relate to the material, whether one of the wooden processes or dural or hollow steel but if I ever had the information for which is which I can't find it! I'm pretty sure differing manufacturers changed the colours throughout the war anyway.
        Jablo blades had a covering known as 'rotoloid' which was a cellulose nitrate based lacquer.
        Earlier Spitfires, certainly BoB era, would normally have had metal propeller blades.
        • colin m
          • 8741
          • Colin
          • Stafford, UK
          Thanks Steve,
          I've seen the bendy blades on pranged early Spitfires, and shattered blades on later Spitfires. So I'm guessing, no weathering for a mk9 blade.
          Who would have thought a simple propeller would cause me so much trouble. I'm not normally too concerned about detail like this, but the propeller does sit in quite a prominent place, so maybe I should make an effort to get it right !
