Weighing down front of model
    Does anyone know how to weigh down the front of a 1/72 Me 262 even though the model has been put together and painted? Thanks
    Blair
    Probably no recess in through th cockpit is there? Perhaps drilling a hole in the inside of the front undercarriage stow area, and dropping some weight through the hole, holding the plane nose down and spraying a little expanding foam in to hold the weight in place, then filling and carefully touching up the hole
    Other than im outta ideas, anyone else?
      That's a great idea! there is a space behind the control panel bit in the cockpit and all the way to the front, so I think I'll open the part in the middle where it's been glued, and I'll put a weight or two in there Thanks for that Dave
      • Alan 45
        • Nov 2012
        • 9833
        Glue it to a base
        • rickoshea52
          • Dec 2011
          • 4076
          • Rick
          I use Deluxe Materials Liquid Gravity to weigh down the nose of aircraft (before I button them up!), you may find it easier to retro fit in your situation.
            I've heard somebody talking about using liquid gravity before, maybe it was you. I can't remember. Sorry but what does retro fit mean?
            • rickoshea52
              • Dec 2011
              • 4076
              • Rick
              Fit or install something after construction.
              • flyjoe180
                • Jan 2012
                • 12415
                • Joe
                • Earth
                http://www.thefreedictionary.com/retrofit
                  Alright thanks
                    Hi all, I tried using 4 or 5 small strips of a 4mm diameter brass rod to weigh down the nose, so it's now sorted Thank you everyone for your help
                    Blair
                      A thread on the build should be up over the next few days as it is very near completion
                      • rickoshea52
                        • Dec 2011
                        • 4076
                        • Rick
                        Blair
                        [ATTACH]137938[/ATTACH]
                        Good recovery and a lesson learned perhaps.
                          Thank you and definitely a lesson learned
                          "Be sure to install weights before gluing the model together"
                          Blair
