I thought I'd be clever and try and spray the bottom wing section of the Spitfire before fixing it to the upper wing and fuselage, but after gluing and fitting and trying to be careful of the cement oozing out of the wing join it proved more of a pain than was worth while. After removing the Tamiya tape keeping the 2 halves together I noticed one or two areas which were not sufficently glued. Not a problem as I just slightly opened the join and applied some cement on a scapel.. job done.
Then I noticed an ever so slight ridge on the leading edge so needed to sand smooth anyway so really no point in spraying the bottom first..... another lesson learnt!! Do you guys build the main model i.e. fuselage, wings etc. before attempting to airbrush or strategically paint parts as you go?
Anyway back to the main point, I noticed a picture somewhere recently of a chap applying liquid cement to the leading edges and fuselage joints after they had been cemented and joined together ? Is this a good method of filling the gaps and making sure the wing edges are fully glued? Is it easy to sand the cemented area when fully dry and get a good finish?
If so what liquid cement is used?
Not a day goes past without me either learning something new, different or having another dozen questions to ask with this new hobby. Thank god for the Scale Model Forum and you guys.... lol.
Atb, Colin.
Atb, Colin.
