Due to it's legendary service, it would seem the Dehavilland Mossie hands down was the best. Recently I looked into the performance details of both planes and the was 410B had powerful engines and comparable speed. Both aircraft are similar in shape with protruding engines set close to the fuselage for better maneuverability. The Mossie, constructed of wood as it was, made it more stealthy. The Brit also had better, more compact radar. Was this then the major advantage? Or was it how the planes were used? If the RAF and Germans had swapped planes, would the RAF still dominate just because they used their resources more cleverly?
Which was really better, The Mosquito or the Me 410?
chrisComment
The 410 was Messerschmidt making the best of the total failure that was the 210......which was supposed to replace the 110.....Comment
Some of the Germans late war aircraft were fantastic designs. Such as the Fw190 D9/11/13 and the Me262. If they had been introduced earlier (when they were actually developed) instead of the bureaucracy limited introduction timescale, then the air war could have been seriously damaged and delayed.
The Me410 was a decent design and as was mentioned above, was introduced as a replacement for the Me210 (which had a stability design fault). The rearward facing guns was a bit of a gimmick and added a lot of weight to the structure. If these had been removed then the Me410 performance figures would have looked a lot better. It was also a very good heavy attack fighter against bombers. But when the superior allied air supremacy came to it's domination, they were shot down in droves (bit like the Me110 G2 and Fw190 A8/R2 or R8).
All in all the mossie was a better aircraft resource wise and could carry a far better bomb load and external stores load.Comment
) did just that.
Since nobody posted a picture of an Me 410 for boatman, here’s one:
[ATTACH]372968[/ATTACH] (via Rod’s Warbirds)
And in case you’re wondering how it differs from an Me 210:
[ATTACH]372969[/ATTACH] (Wikipedia)
The name for this phenomenon is “thread necromancy”.Comment
