Spotted on Twitter
  • Peter Gillson
    • 2594
    Spotted on Twitter
    Hi Guys
    I do not know how to insert a link to Twitter so here is a photo takne from a posting by "usina dos Kits" which has some of the most effective ground work I have seen.
    [ATTACH]316662[/ATTACH]
  • prichrd1
    • 691
    • Conwy
    Peter,
    Coastal Kits - they do a selection of "ground blur" display bases in 1:72 / 1:48 / 1:144 scales.
    Paul.
    :smiling2:
      Should be fairly easy to make yourself with an aerial photograph, an image editor, a printer, though.
      • Peter Gillson
        • 2594
        Peter - i suppose i should not be surprised that somebody produces this type of base, although 'i had not come across one before.
        Jakko - depending on the ground being depicted it may be possible to replicate with oil paints and normal ground work techniques, although since I am not into aircraft it is not something I will try to do.
          If you’re a good enough painter you can replicate anything that way — for us mere mortals, an image editor is probably quicker, simpler, and gives better results
