Africa BF110 colours?
    Hi all.
    Planing to do a 1/72 new Airfix BF 110 in Africa core sceeme.
    Were they just brown over light blue (RLM unknown for now) or were they mottled like the 109 E's?
    Since I broke my fine airbrush I need to choose subjects that are easier to paint LOL!
    Thanx
    Theuns
    PS. I read good reviews on this plane, anyone built one?
  • AlanG
    • 6296
    Search for aircraft from III/ZG26
    RLM 79 over RLM 78
    http://img.wp.scn.ru/camms/ar/318/pics/2_16_b2.jpg
    http://www.asisbiz.com/il2/Bf-110/Bf-110-ZG26.3/images/1-Bf-110E-III.ZG26-(3U+-B)-North-Africa-01.jpg
    http://www.germanaircraftwwii.com/img/upload/2pru4va.jpg
    http://www.asisbiz.com/il2/Bf-110/Bf-110-ZG26.3-(TF+KH)/images/0-Messerschmitt-Bf-110E-III.ZG26-(TF+KH)-Libya-1942-0A.jpg
    • Dave W
      • Jan 2011
      • 4713
      Hi Theuns.When i was researching ME110 colours some time ago i found some profiles of aircraft used in North Africa.They were painted RLM78 'Himmelblau' on the undersides with RLM79 'Sandbraun' on uppersurfaces only.Being Luftwaffe there were probably several different schemes used.Hopefully someone who knows more about the subject will be able to give you a better answer.
      • stona
        • Jul 2008
        • 9889
        Hi Theuns,the lads are quite right,79 over 78 with a very low demarcation line was standard. Of course being the Luftwaffe all sorts of mottles and squiggles (usually in RLM 80) were applied to some aircraft.
          OK thanx guys. I will have a closer look at the Kit's colours and hope that it is a uniform brown as my current airbrush can't do squigles!
          I will try to find a pic of the kit box art and show you.
          Theuns
            To my untrained Mk 1 Eyeball this looks plain brown???
            If so I will build this kit soon.
            Theuns
            [ATTACH]39412.IPB[/ATTACH]
            [ATTACH]39413.IPB[/ATTACH]
            • AlanG
              • 6296
              RLM 78 = Humbrol 65, Tamiya XF-53, Xtracrylix XA1214
              RLM 79 = Humbrol 62/63/118, Tamiya XF-52/59, Vallejo Model Air VAL 33/34, Xtracrylix XA1209
              • yak face
                • Jun 2009
                • 13824
                • Tony
                Good choice theuns, ive been looking at this one too. Ive heard good reviews as well, think ill have to get one! cheers tony
                • stona
                  • Jul 2008
                  • 9889
                  Cool,both ZG 26. I like the E-2 with the longer fuselage and white cowlings.
                    SO just to confirm then - this is plain brown ontop???
                    How do these colours of my 109 compare, close enough?
                    T
                    [ATTACH]39416.IPB[/ATTACH]
                    • stona
                      • Jul 2008
                      • 9889
                      Originally posted by \
                      SO just to confirm then - this is plain brown ontop???How do these colours of my 109 compare, close enough?
                      T
                      Yes and yes!
                        Would the demarcation line between the blue and the brown be the same as a "standard" 20-30mm wide spray line, or is it a more "gradual" fade in?
                        In 1/72 it would almost be a hard line.
                        Theuns
                        • stona
                          • Jul 2008
                          • 9889
                          Very much depends when and where the camouflage was applied. It was not masked so there was always a certain amount of 'fade in'. In 1/72 this is indeed effectively a hard line but it's an artistic decision on a model.
                            Thanx Steve, I'll give it a bit of a fade for effect
                            T
