Broken canopy - help!
    All the canopies on my 1:72 FG.1 Phantom have broken.
    Hannants shows the only vacform canopy they offer as out of stock, and to save paying £25 for a whole new kit, does anyone have any suggestions?
  • AlanG
    • 6296
    Depending which manufacturer the model is from could you not contact them and see if they could send you a spare? I know Revell and Airfix are normally really good at doing this
      Are they? Good tip, I’ll give that a try, thanks.
      Are there any ‘pro’ tips for repairing / replacing them in case it ever happens again?
      I realise the obvious answer is not to break it in the first place....
      • AlanG
        • 6296
        To be honest i've never broken one before so i couldn't suggest a repair. But given the join would be visible i'd just ask for a new one lol
        P.S. Welcome to the forum
          Nope, me either, which is why I’m at a loss as what to do!
          And thanks, appreciate the welcome.
            • 18903
            I wrecked a canopy on an Italeri Stuka once, and got a replacement direct from Italeri. They were really helpful. Failing that, searching the net to source the vac form somewhere else is the only option I can offer.
            • Gern
              • 9214
              If it's broken across the 'glass' part, even if you can glue it together you'll always be able to see the joint. If it's under the canopy framing, there are several types of PVA available which would work and your painted frame would hide most, if not all of the joint.
                • 18903
                Oh, and welcome from me as well :thumb2:
                  Thanks!
                  The damage is right across the ‘spine’, i.e. straight across the top in line with the axis. Classic pinch crack I suppose!
                  Looked for a vacform. Found one online for around €2.50.
                  Postage however was €12 from mainland europe!
                  I’ll get in touch with airfix and see what they say.
                    Revell and Airfix both have on-line request sheets for spares - I've used the Revell service a few times, good, but it takes time!
                      I’ll try to find the form, useful to know its there and what I shoukd be looking for.
                      Thanks Dave!
                        Found the form and submitted.
                        Auto response states that for airfix spares I should allow 28 days. Not clear whether this is for a response or the spare.
                        I guess I’ll start my harrier frs1 while I wait!
                          Some years ago I had an Airfix kit that had two sets of upper wing halves but no lower wing halves, so I got t in touch with them about it, and I don’t think you’ll get a reply, just an envelope with the part(s).
                            Excellent! I’ll keep an eye out for it.
                            BTW, they didn’t say ‘no’ explicitly to my little p.s. asking for an advance on the buccaneer...
                              I had a canopy missing from a Minicraft kit. I e-mailed Minicraft in the USA requesting a replacement part and for a PayPal invoice to cover costs. No reply but a few weeks later the part arrived in the post without charge or comment. Quite something.
                              George
