Beaufighter help please.
  • Mickc1440
    • 4779
    As the build progresses I'm looking to model the aircraft on the ground with it's waiting crew. There are two crew access panels to model in the open position. Only the pilots door has a small section of ladder and nothing on the navigators. I'm struggling to find a pic to help, the ones I have found have only confused me more. Can anyone help please?
  • SimonT
    • 2824
    [ATTACH]350664[/ATTACH][ATTACH]350665[/ATTACH]
    Hi Mick,
    these are the pilots door with ladder looking from the front and rear
    [ATTACH]350666[/ATTACH]
    this also shows the gunners hatch - no sign of a ladder presumably as it is nearer to the ground
    Looking at the chaps loading ammo they are slightly crouched next to the front door so a chap standing up in the gunners doorway would have the bottom of the fuselage roughly level with his thighs so could probably pull himself up from there (or there could be a foot hold on the back of the door I suppose - can't find any pics from the other side)
    • Mickc1440
      • 4779
      Thanks for that Si I'd seen the pilot ones but not the bottom one, it makes sense that the recess in the rear door is a foot step. I managed to find a blurry pic of the ladder stowed which then blocks up the hole in the pilots door but can't see how it works, never mind that's a huge help.
      • SimonT
        • 2824
Name:	Screenshot 2019-07-19 at 05.53.01.png
        does this help Mick?
        looking at the closed position it possibly pivots on the pins in the yellow circle and they then slide in the channels (red oval)
        Best guess - opening procedure is probably something like release lock, pull ladder forward and down so it slides forward whilst pivoting then when the pins reach slots they drop in and lock it in place
          Hi Mick his may ormay not help.
          [ATTACH=CONFIG]n[/ATTACH]
          [ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
          Pete.
          • Mickc1440
            • 4779
            Si and Pete brilliant thank you, the ladder doesn’t stow away, thanks very much
            • yak face
              • Jun 2009
              • 13840
              • Tony
              Hi mick ,sorry i missed this but heres a bit more info for you . The square recesses in both doors are spring loaded foot steps, in the pic where both doors can be seen open youre looking at the inside surface so you can see the footstep as a recess , the other side ( exterior facing ) is flush . The pic of the aussie beaufighter with the hole in the door just shows that the footstep has ben removed/ lost . The rear door is similar to the front in operation , ie pivoted in the middle and folding down from the front edge so the visible part is actually the inside surface. On the rear hatch the area covered by the front part of the door and visible when it swings down would contain the oil damped struts and latch . Heres a few pics from the modellers datafile hope this helps , cheers tony
              • Mickc1440
                • 4779
                Hi Tony, that makes things even clearer thank you
