"Real" colours for Hurri Mk1 (BOB)?
    Hi all. I got the 1/72 Airfix Huricane Mk1 today as a fun quick build.
    The decals I want to use is for # 87 Sqn RAF Aug 1940.
    What are the correct humbrol green to use? # 30 seems to be to "green" but # 29 dark earth looks OKish.
    Thanx
    Theuns
    • 18266
    well a quick look in the paint box and by comparing the lid from Xtracrylix to the lids of Humbrol, the one that I think comes nearest is humbrol 116. Even if they call it US dark green!
    I agree that the Humbrol green #30 is a bit green!
    • stona
      • Jul 2008
      • 9889
      I don't use the Humbrol colours but most seem to find Humbrol 30 to be too green in the sense of blue/green. RAF Dark Green has a more Olive tinge to it.
      It's very hard to describe these things in words
        Some googling led me to the IPMS Stockholm site and it seems HU 116 is a good match, thanx guys.
        Now, the plans call for "Sky" underside, again no "out the tin" thing there. Some say HU #65 Aircraft blue , or maybe Duck egg blue. Close enough???
        The box art however shows a Hurri with a white underside. Was this common during ops in France? White will be easier than the blue.
        I opened the Hurrie's box expecting to be al surprized with the quality like with the Bf 110 new tool, but it turns out to be an old kit just re-boxed :-(
        Raised detail, poor fit and absolutely no cockpit or wheel well detail atall!
        I sanded the detail of the left wing and re-scribed, looks a tad better I think. I might just slap in the pilot and put the wheels in to hide the wells.
        Theuns
        [ATTACH]41283.IPB[/ATTACH]
        [ATTACH]41284.IPB[/ATTACH]
        [ATTACH]41285.IPB[/ATTACH]
          I see now HU 90 "beige green " is called for the underside. But I would still like to know if they were maybe also white on the underside in France 1940 ???
          Interestilnly the decals for the side code shows the left side to read "LK-A" but the other side is "A-LK" This I find strange!
          Theuns
          • stona
            • Jul 2008
            • 9889
            Hi Theuns,as far as the underside goes for the BoB period the best colour would be Sky,though there are certainly other possibilities. There was never a white underside. Whilst in France (this was the period known as the Battle of France and pre dates the Battle of Britain) Hurricanes would have had a black/white underside.
            Humbrol 65 (aircraft blue) and Humbrol 23 (duck egg blue) are both blue colours and neither is much like Sky. Sky is something entirely different and has a distinctly green hue. There is much gnashing of teeth about a good Sky colour but,if you want a Humbrol colour straight out of the tin,go for 90 (beige green).
            I'd lighten it up a little,but it's in the right ball park.
              Ok thanx Steve. I will do the # 90 thing, just a very strange colour to use on the underside.........unless you lads have a green sky up north LOL!
              Theuns
              • stona
                • Jul 2008
                • 9889
                Hi Theuns, the colour Sky was the same as an earlier experimental colour called Camotint. This had been developed by a remarkable Australian, Sidney Cotton. He's well worth a google! It was found to give excellent camouflage when viewing an aircraft at medium altitudes from below. Pilots had complained that the earlier Black/White underside made them far easier to see than their Luftwaffe counterparts sporting blue RLM 65 undersides.
                Sky was replaced later in the war with Medium Sea Grey on fighter undersides but reappeared post war. I have pictures of my father's 801 Sqn. Sea Furies with Sky undersides in the early 1950s and,later, colour pictures of Whirlwind helicopters with a lower surface colour very similar. I'm not sure whether it was still called Sky by then.
                  Interesting info, thanx
                  I did get hold of some HU 90 Sky and Hu 116 green.
                  Theuns
                    • 18266
                    I have a suspicion that the 'sky' colour might of arisen from the fact that a good time for raids was early morning/early evening. Sun low in the sky and all that. ("We will raid them at dawn" seems to pop up a lot). The early morning sky can often be seen to have a green tint to it... I wonder if that could have had anything to do with the choice of colour?
                    I agree with Steve that Hu90 is in the right range but will look better with a couple of drops of white to lighten it.
                      Thanx
                      I have completed the basic construction and have shot on a coat of primer to check my re-scribing effort. Som fine touches to be done and then I will do the colours. I just hope that the decals conform well, the fin flash is the big one that covers the whole fin. Interestingly the side roundal has a small section of the outer yellow cut off to follow the line of the sky. Not sure why it was done like this.
                      Theuns
                      • stona
                        • Jul 2008
                        • 9889
                        Originally posted by \
                        I have a suspicion that the 'sky' colour might of arisen from the fact that a good time for raids was early morning/early evening. Sun low in the sky and all that. ("We will raid them at dawn" seems to pop up a lot). The early morning sky can often be seen to have a green tint to it... I wonder if that could have had anything to do with the choice of colour?Ian M
                        Hi Ian, the colour Sky was the same as Camotint and was initially developed for camouflage of photo reconnaissance aircraft as remembered by Sir Neil Wheeler.
                        Wheeler was neither the first,nor last,to describe Sky as "duck-egg blue". This caused confusion at the time and ever since. The colour is not really blue at all. There was a signal issued around the time of the adoption of the then new colour Sky allowing for it to be described as "duck egg blueish green" which is at least a bit closer.
                        To add further confusion the "sky-blue we know so well" does not refer to the already existing colour Sky Blue but to either Sky ( if Wheeler has remebered his dates correctly) or possibly PRU Blue! The quote is taken from an RAF Historical Society meeting about photo reconnaissance.
                        This document is courtesy of Edgar Brooks. I suspect it was to make the point that Sky was NOT the already existing colour Sky Blue but a new colour identical to Cotton's Camotint.
                        Another document (again courtesy of Edgar) makes it quite clear that Camotint and Sky are the same colour and also describes this colour more accurately as "pale blue-green"
                        I imagine it was called Sky because it gave camouflage against the sky! As simple as that. The same reason Dark Earth and Mid Stone were so named.
                          Thanx Interestingly the side roundal has a small section of the outer yellow cut off to follow the line of the sky. Not sure why it was done like this.
                          It was because the upper colours were not supposed to overlap the underside colour(s.) The yellow was to make recognition at the same level more positive. The Sky was to make the fighters invisible to bombers flying below, and a splash of yellow wouldn't have helped.
                          Edgar
                            I see now HU 90 "beige green " is called for the underside. But I would still like to know if they were maybe also white on the underside in France 1940 ???Interestilnly the decals for the side code shows the left side to read "LK-A" but the other side is "A-LK" This I find strange!
                            The black/white undersides were (supposed to be) overpainted in Sky from June 6th., after Dunkirk; shortage of paint (at first Titanine were the sole suppliers) meant that some Squadrons kept the black/white, while other s tried to mix their own, and there's a possibility that some took Sky Blue (used on drones like the Queen Bee) and Sky to be the same colour.
                            The order, for the code letters, simply stated that the Squadron two-letter code had to be on one side of the roundel, with the aircraft's individual letter on the other. Early codes were supposed to be 3'(36") or 4'(48") in height, which meant that Squadrons struggled to fit them onto fighter fuselages, and some Spitfire (check "DW") codes went across the wingroot fairings. Eventually fighters were standardised at 2' (24") with Spitfires getting a special dispensation to go down to 20". This is why it pays to have a good look at any photos that you can get your hands on.
                            Edgar
                            • stona
                              • Jul 2008
                              • 9889
                              This is the sort of thing Edgar is alluding to.
