Modern RN weapons trolley
    Does anyone know if you can get a 1/72 modern royal navy weapons trolley?
    i wanted to show my merlin with its torpedos on a trolley next to it.
    even if somone just has a pic or some diagrams and dementions that would help.
    thanks
    Hi Richard,
    Try these on this link,
    They may have something along the right lines for you, have a look at ones towards the bottom of the page or even some of the ones for the Tornado's etc. All the relevant ground support equipment is covered and they do them in 1/32nd too !!
    Regards.....Mark
      thanks mark.
      i might be able to use the oxygen trolley. but it is all RAF stuff not RN and im not sure how much different they are.
      i cant find anything else though so i think it will have to do.
      cheers mark.
        Hi Richard,
        The Header at the top of that page does say it is RAF/RN stuff so I would have thought it would do for what you want. Seeing as most Brit stuff is same be it RAF/RN especially aircraft, (except for the landing gear on some planes), It is generally the aircraft that are modified for Navy Use but the ground support kit on Carriers is pretty much the same as the land kit.
        Regards.........Mark
          cheers.
          do you think the loading trolley or the oxygen trolley would be more appropriate for torpedos? the pilons on the merlin are not high enough to use that trolley i dont think anyway.
            another thing i just noticed....how do order this stuff?
            i have had something done by flightpath before but i honestly cant remember how i got it lol.
            edit...
            never mind, found an order form/e-mail address bit.
              Hi Richard,
              Good luck with the orders, The trollies could always be modified to what you want, at least you will have the basics there to work on.
              Regards........Mark.
