Modern Chinese Aircraft
    Hey guys and gals.
    Was doing some research and thinking of building some of the more modern Chinese fifth generation fighters. (J-10, FC-1, etc). Does anyone know of any 1/48 kits out there for these?
    Hi Mike,
    Not sure about 1/48th scale but kits do exist for the J-10 - check the following link:
    Might be worth checking them out to see if they do a 1/48th version.
    Regards.....Mark
      Thanks, Mark. Now I at least have a starting point.
        No Problem Mike,
        As you have probably guessed that is the Trumpeter Kit, they do some nice models in their range too.
        Meanwhile, Howabout a pair of Radio Controlled J-10'S both powered by Turbine engines..??
        Enjoy the video !!
        Regards.......Mark.
          I've done a few trumpeter kits and have enjoyed them immensely, they are typically of high quality and a pleasure to build as a result. I'm still on the fence about getting this one... I'm almost religious about 1/48 stuff.
          As far as the video... holy smokes. That kind of timing control is hard enough from the cockpit, let alone from a hundred meters. Impressive video, thanks!
