OK, this is not as hard to do as it seems, there wont be any "paint" involved in this method, although there is a specialty product you will need to get.
It is called "Rub and Buff" gold tinted wax. You can find it in craft supply stores or i will give you a link to suppliers at the end of this post. here is the description of the product:
"Made from imported carnauba waxes, fine metallic powders, and select pigments, Rub 'n Buff gives almost any surface a new look in minutes. This unique blend gives objects decorated with Rub 'n Buff a finish that no paint can duplicate. It can be applied to any clean, dry surface as well as over previously painted surfaces. One 1/2 oz. tube covers up to 20 square feet. "
I have used this product before and on clear surfaces, it can be applied in a manner that will tint, but not make "opaque". Just wipe it on and wipe it off until you achieve the tint you want.
In this particular use, i would suggest using it on the "Inside" of the canopy glass.
You can find it by searching for "Rub and Buff" in google, here is the linnks i was given, google UK may provide links to shops in your area.
Hi I use Tamiya smoke with a hint of gold thinned for airbrushing and misted on so it goes on evenly and without runs. Being acrylic any problems it will wash off with soap and water. Hope this helps
