It's a long shot, but I'm after an Italian torpedo plane of wwll vintage. I'm wanting a photo at a particular angle. Of course the www never has the right pic. It's for a diorama background I'm thinking of.
Hopefully
Andy
The best known Italian Torpedo bomber was the Savoia-Marchetti SM79 Sparviero - loads of pictures around................
[ATTACH=CONFIG]n1215171[/ATTACH]
Hi Dave, yep that's the problem, loads of pictures around but all like the above.
Should have said in the thread, I'm after a pic but from behind with the plane in a slight climb like it's just dropped the torpedo. Yep, don't want much...
If it plane specific!! That will be a long shot. I’d you just want the aircraft’s attitude post dropping there maybe more chance. Eg, try searching swordfish torpedo drops!!
On the other hand if it’s the torpedo your after, search any airborne launch. They pretty much all fall the same!!
Probably right, it will be at such a distance, does it really matter, as long as its a plane. Not sure about the swordfish though, torpedoing one of HMSs, humm perhaps not. lol
War Thunder has the S.M. 79, and it’s apparently capable of carrying a torpedo in the game as well. All you need to do is find someone who plays War Thunder and has that plane, then get them to make some screenshots of dropping a torpedo with it
Your best bet is if you can find books on the SM79 - I know that there are at least two three - one Italian, the other Polish - there may be some action shots in them - I'll have a look around....................
this just popped up in my search!
Jakko
Didn't think of gaming, could be screen shots, will have a look.
Yes books would be another option. Don't want to put people to a lot of trouble as I'm not sure if what I'm trying will work. If I'm honest I'm having doubts.
I've probably got something close in my books. The Squadron Signal book Dave shows has a photo of an S.79 from rear three quarters passing a freighter. Another pic I have shows two S.79s attacking HMS Barham, and one 'plane has just loosed it's torp. The pic is a bit small and may be a wartime propaganda fake. I'll do some scans soon as I can
Oh, you may also be able to find a piece of film of an S.79 passing over a British destroyer, filmed from the deck. I think it was used in 'In which we serve'
What has to be taken into the equation is when dropping ordinance from an aircraft. One of the laws of aerodynamics come into force.
You drop quite a few hundred pounds of weight, weight and lift are opposites. So, when you drop weight, lift takes over and aircraft tend to rise very quickly!! I have heard the term, 'jumped' when in relation to dropping a load!!
(In the tiny Wasp, when we dropped a torpedo or pair of depth charges we could feel the rise which the pilot then has to take immediate correctional inputs to the controls!!)
Additionally, there may be operational procedures pilots may be required to carry out. eg, bank hard over or climb rapidly. Not withstanding ducking and diving from incoming weapons!!
Another thought, images from astern of the dropping aircraft are going to be like dragons teeth!! Most aircraft astern will be in the same boat as the dropping aircraft, that is pilot concentrating on the target and not clutching a camera. That said, there may be rare images of a drop during perhaps a trial or test drop. I say rare because most developers of weapons would be owned by the companies.
I'll keep on scouring the net in the time being Andy!! I have only images of DC's being dropped.
These any good for you?
[ATTACH=CONFIG]n1215179[/ATTACH]
This is from the Squadron Signal book
[ATTACH=CONFIG]n1215180[/ATTACH]
S.79 bombers rather than torpedo, but maybe the right angle?
This is the possible propaganda picture
[ATTACH=CONFIG]n1215181[/ATTACH]
The S.84 was the dedicated aerosilurante (torpedo bomber) variant of the S.79
[ATTACH=CONFIG]n1215182[/ATTACH]
Hi, that is perfect for what I want, should be able to photoshop the rest of the wing.
Sorry still not got the hang of answering multi postings yet.
But thank you all for your help in this. Now just got to put all the railing on the deck and see how it goes.
Thanks again, as always the members come though.
