Hi Guys,I said some time ago that i would let you know how this build was going... well, im prety well into it now and have loads of pics to show you. Despite my many attempts to add these pics i still cant get the hang of it. I have tried clicking on the icon above and it does nothing. I have also looked at the unhelpful Help files and cant find the answer. Anyone got any pointers please.
P47-D Thunderbolt 1/8th Scale
GuestTags: None
If you have them on your computer, just go to reply, write what you want , then go down the board to , manage attachments, click there, it will open and you will see Browes, click on that , it will go to your computer, sellect your file and picture, then go to browes again and repeat. -
P47-d
Originally posted by \Hi Guys,I said some time ago that i would let you know how this build was going... well, im prety well into it now and have loads of pics to show you. Despite my many attempts to add these pics i still cant get the hang of it. I have tried clicking on the icon above and it does nothing. I have also looked at the unhelpful Help files and cant find the answer. Anyone got any pointers please.Comment
Hi Skyraider,
Have a look at the pic below - you should see either the manage attachments button as arrowed or the go advanced button, if you click on the go advanced it will also bring up the manage attachments button in an additional box below the reply box (scroll down the page if need be) - try it and then follow the steps as posted by ron above.
Regards......Mark.
[ATTACH]17378.IPB[/ATTACH]
Thanks for the advice i will give it a try later, in the meantime i have just uploaded a load of pics in the Gallery section. Im not sure if this is a good place to put them because it doesnt tell anyone that they are there. They are in Under Construction section. Thanks again for you help MarkAndyComment
No good mate. In the section of the screen shot it says Attach FilesValid file extensions: gif jpeg jpg txt zip. Then in advanced there is notning at all to click on to add or upload files/images. I gues i will just have to live with it.Thanks again.AndyComment
Originally posted by \Once the pictures are in the gallery just follow the steps in this post.http://www.scale-models.co.uk/planes/2606-albatross-c1-4.html#post34065
Hope this helpsComment
Sorry if I got the "wrong end of the stick", is the problem you're having getting more photos into your gallery or inserting a gallery photo into a post?
The build is looking good, for a first real build it's very impressive and would certainly make an interesting "Under Construction" thread. I'm looking forward to it!Comment
Originally posted by \Here,s 2 pictures I took ,It might help.Comment
Andy,
Have a look under my reply now - you should see a quick reply box and on that will be the manage attachements button, that is the one you want - if you type a reply yourself you will see it below as you can on this reply now
The go advanced option should also be there.
Regards......Mark.
[ATTACH]17385.IPB[/ATTACH]
Originally posted by \Sorry if I got the "wrong end of the stick", is the problem you're having getting more photos into your gallery or inserting a gallery photo into a post?The build is looking good, for a first real build it's very impressive and would certainly make an interesting "Under Construction" thread. I'm looking forward to it!Comment
Originally posted by \Andy,Have a look under my reply now - you should see a quick reply box and on that will be the manage attachements button, that is the one you want - if you type a reply yourself you will see it below as you can on this reply now
Regards......Mark.Comment
Originally posted by \No good Mark, If i knew how to take a screen shot like you have i could show you what i have got. I do have exactly what you are showing but the attacment button isnt there.Andy
I assume from your previous posts you are using the reply button in the bottom right corner of the box - if so scroll down the page a bit and you will see the magical button you are looking for.
Have a look at my screen shot now.
Regards......Mark.
[ATTACH]17386.IPB[/ATTACH]
