How do i apply the to my models do i paint it on or use a cloth? i now i sound thick but never used it before thanks guys
Jonhson klear
GuestTags: None
You can paint it on. Use a wide soft brush. Be carefull not to get to much on,a thin coat will suffice. It is a self levelling floor polish so brush marks will not be a problem. I always check around the edges of the surface opposite the one I am applying it to as any excess can pool here. If you do make a mess it is easily removed by any reagent containing ammonia (many window cleaning solutions for example.
Steve -
You can also use your airbrush but remember to give your airbrush a good clean as soon as your done.Comment
