!/72 Academy PBY CAT
    I am busy with this 1/72 Cat and this is what I have done so far.
    Some filling was requred on the joints, not much though.
    I have also cut off and reglued the elevators back in the down position as they were on the ground.
    Will be painted in the US military Pacific collours of white bottom and medium blue top.
    What can I use to mask off the windows for painting, I have heard of "mask all" but will something like that work on small windows/
    Some one I know have used white pva wood glue thinned with water in the same manner and said itcame off without any hassle and worked well.
    Or is good old masking tape still the only real way?
    Thoughts please.
    Thanx
    Theuns
    [ATTACH]19604.IPB[/ATTACH]
    [ATTACH]19605.IPB[/ATTACH]
    Theuns, There are masks available for your aircraft, see link below. Hannants - Eduard EDCX115 - 1:72
    I use these, also 6mm wide Tamiya Masking Tape.
    Look forward to seeing more of your model, I like the Cat's Derek
      Derek, I am looking at something like this pic maybe.
      Simple to mask and rather pretty I think.
      The masking will be done with the tamia tape, it is just the windows that I am a little worried about.Will use the wood glue trick and hope for the best.
      There is a lot of work still to try and restore the pannel lines and rivets that are sanded away when filling.
      This is by no means a "high quality" name brand model,just a fun project.So if the blue doesn't macf perfectly I am not to worried about it.
      Later
      Theuns
      [ATTACH]19607.IPB[/ATTACH]
      [ATTACH]19608.IPB[/ATTACH]
      • stona
        • Jul 2008
        • 9889
        Liquid masks (BTW tippex or whatever they call liquid paper in S.A. is a cheap option) may work on your small windows but for anything with a frame good old fashioned masking and a sharp blade work best. I use regular Tamiya tape or on more complex frames Parafilm M.
        I cut the masking along the frame edge using a new curved scalpel blade and a rocking action to avoid scoring the clear part. I make sure the edges are pushed down using a wooden cocktail stick with the end cut at about 45 degrees.
        I mask small windows, the type you fix from the inside, with masking tape BEFORE I glue them into the fuselage. I learned the hard way that masking them later can lead to little clear windows rattling around inside the model! They may be impossible to retrieve.
        Keep up the good work.
          Thanx so far.
          Does the tippex tipe stuff not contain a solvent of sorts that might "eat" the clear plastic?
          The wood glue trick I know uses a couple of coats aplied into corners with a toothpick and small brush to build up a masking skin over the plastic.Then after painting a sharp blade is used to lift a corner and peel off the skin.Or at least so the theory goes, I will keep you posted
          I got the good old humbrol collour chart out today and tried tomach the pix I posted.The best I could comeupwith was # 109 WW1 blue. Tne # 89 middle blue looked to light.
          But then again there were so many different shades of blue due to fading that it will never mach anyway.
          What I am thinking to do is do use very slightly different shades of blue on the metal and fabric covered parts to simulate the way metal and fabric paints"age" over time.
          Another difficult thing to do will to try and get the waterline staining on the hull right ,any ideas???
          Theuns
          • stona
            • Jul 2008
            • 9889
            Originally posted by \
            Thanx so far.Does the tippex tipe stuff not contain a solvent of sorts that might "eat" the clear plastic?
            Theuns
            I've not tried Tippex on clear but it is fine on regular styrene. I nicked it from SWMBO's office when my old liquid mask had dried in the bottle!
            Your different shades is what we do with an airbrush when we post shade. I typically lighten the centre of various panels. I don't see why you couldn't do this with a brush. I'm no expert at brush painting but could you not, for example, dry brush a lighter shade on the ribs of the cloth covered control surfaces to simulate that differential fading? Also as you suggest using different shades on metal and fabric skins/covering. I'd just add a drop or two of white to your base colour, you don't want to over do it.
            I saw an article in which someone was simulating exactly that type of staining to the hull of a flying boat, a Sunderland I think. I will try to find it for you.
              Thanx Steve.
              I was also thinking that drybrushing would be the awnser.The rib detail is to small for airbrushing.
              I know that the paint does'nt allways fade in perfect unisin.Some paches are lighter than others.
              Just read some sad news.There was a prop-liner that crashed into a school here in SA this morning.Fortunately it is a holiday and only crew onboard.Teriable situation.
              I will be happy if you could share on how to do the water stains.
              Thanx
              Theuns
                Well all the filling/sanding done and as usal some panel lines/rivets gone aswell :-(
                I will start painting this week if weather gets better.
                I read that I need to aply a coat of clear gloss before aplying decals and then clear matt.Do I put gloss only where the decals go or allover?
                If I put gloss only at decal location ,what effect will the matt then have over the whole thing???Will it blend evenly where no gloss is?
                Theuns
                • stona
                  • Jul 2008
                  • 9889
                  I gloss the whole model. You need a gloss i.e. smooth surface to help prevent minute air bubbles being trapped beneath the decals, causing the dreaded silvering. This gloss coat will also protect your lovingly applied paint job from any mishaps during weathering etc.
                  It is much easier to remove excess wash or just stuff that has got in the wrong place from a gloss surface! You can then seal everything in with your top coat (matt or silk)
                  I can't find that flying boat build, but I'll keep looking.
                    Ok will do the gloss thing.
                    Just tried to put Tamia white acrylic on the wing with an airbrush, but it doesn't work all that well.Doesnt stick to the plastic, it "pools" and pulls away from jointlines ect. Why??
                    I think I will stick to enamels.
                    Theuns
                    • stona
                      • Jul 2008
                      • 9889
                      Hi again. First your acrylic problem. Have you given the plastic a good wash. The residue of the mould release agents is one possible cause. I always prime the bare plastic before I apply acrylic paint, a step not necassary for enamels.
                      As for the hull there is an interesting discussion about different paint types applied to British flying boats here:
                      http://theflyingboatforum.hostingdelivered.com/viewtopic.php?f=15&t=367
                      I found this picture which may illustrate the point:
                      And also one being dragged from the water:
                      Not your machine , I know, but the principles may be the same!
                      [ATTACH]19670.IPB[/ATTACH]
                      [ATTACH]19671.IPB[/ATTACH]
                        Wow, talk about "man power"
                        It is interesting that the staining of darker collour is above the waterline, one would expect it to by darker below the water with all the stuff in water.
                        What do u wach the model with before acriycs? Just soapy warm water?
                        I will have a look at that link thanx.
                        Theuns
                          Ok will do the gloss thing.Just tried to put Tamia white acrylic on the wing with an airbrush, but it doesn't work all that well.Doesnt stick to the plastic, it "pools" and pulls away from jointlines ect. Why??
                          Theuns
                          Theuns, I give my models a wipe with an anti-static cloth (as used in cars for dashboards), then spray with Tamiya Fine Surface Primer from their rattle can 9comes in white and light grey), not airbrush. Dries very quickly. Derek
                          [ATTACH]19672.IPB[/ATTACH]
                            So here is the problem, I have been painting the plane gloss white humbrol and promptly ran out before finnishing.
                            Will tamia acrylic "take and stick" on enamel??
                            Theuns
                            • yak face
                              • Jun 2009
                              • 13831
                              • Tony
                              hi theuns,nice to see the cat coming along,as for the paint,usually acrylics wont go over enamels ,something to do with the enamel being oil based,if i were you id get some more enamel, to be on the safe side.looking forward to seeing her completed, cheers tony
