I am building scale model of Auster 1 from DB Sport AUSTER J 1
and I have decided not to use their included tailwheel partially because I didnt like it /piece of bended wire/ and partially because by original construction the tailwheel was supposed to be attached to the rudder and I was in doubt if the rudder is sturdy enough for such a task.
I bought DuBro tailwheel http://www.brhobbies.com/prodimages/DUBQ0956.JPG which I would like to use instead.
Now my question finally :clap2:
If I leave the tailwheel free, unattached to the rudder or servo, will I still be able to taxi my model normally - performing turns on the ground? Will the propeller stream be enough as a force when I apply the rudder to make model turn on the ground???
Thank you !!!
Thank you !!!
