Anybody know a source of 5mm foam-board. That is the stuff used for mounting photographs. Looks like pizza tray with paper on both sizes. Need larger than normally found in art supply shops. I believe architectural models use it. Thanks.
Foam Board source in UK
GuestTags: None
you could possibly try a photorgraphic wholesale or, try a local camera shop.
other than that m8 a architectural material supplier. -
Art and Craft shops sell it,also picture framers use it as backing for pictures.
The white board is about £8.50 per panel and the black is double the price for some reason ? makes a great building board after mounting onto a flat surface with spraymount adhesive,takes pins easily and a pleasure to use.
If you need a wholesale source try a search on the net via Google.Comment
Built from Foamboard.
Thought that you would like to see my experimental proof of concept De Havilland Dragon twin made entirely from Foamboard apart from a few strips of balsa.
[ATTACH]6849.IPB[/ATTACH]
[IMG]/monthly_2004_04/0e5009c0.jpg.5575534dad423bcc7b89777118c5073d.jpg[/IMG]
[ATTACH]11494.IPB[/ATTACH]
[ATTACH]12144.IPB[/ATTACH]
Attached FilesComment
Yes, good modeling material. Not in the same leaque as Wonwinglo's complete foamboard aircraft but, the booms on the twin boom pusher pic attached were from foamboard too. Worked well, never any problem, and took Solarfilm without problems.
I've seen footage of an 80" span completely foamboard delta flying in America. Lovely!
[ATTACH]6851.IPB[/ATTACH]
[IMG]/monthly_2004_04/Orange3-.jpg.5c46d6c50b802c830a72bdee4476828f.jpg[/IMG]
[ATTACH]11496.IPB[/ATTACH]
[ATTACH]12146.IPB[/ATTACH]
Great pics guys, Foam is for a mate who has got a set of plans from US for a Mud Duck. He thought it was for a 25 , so it was...25cc ! it`is ginormous, kinda cute as they would say. Sort of Lazy bee cultish. However a free set of a low-wing version called Agri-Duck (crop-dusterish) took my fancy and the plan is free. may be a winter project for me:thumbs:Comment
Thanks for ideas guys, Ive found a source in Scotland . There are three UK sources for the stuff. No wonder I couldnt find it...try www.fomecor.com. What a variety including a "wood look finish", just the job for the finger-pokers who ask "what s it made of?":lol:Comment
Foam Board source UK
I would like to investigate growing this market. Anybody like to build me a prototype plane with plans so that I can market my foam products in the UK?Comment
Matthew as foam board is basicly Depron coverd with quality paper its a doddle to transfer most of the free depron designs over if they are not too curvy ..the added wt can cause problems on smaller models but they usually peel it off one or both sideds....
Teaching science and DT I've used it quite a bit........ in fact Duncan - most primary and virtually all secondary schools use lots of the stuff...they tend to buy it through the education suppliers which dictates cost /size/thicknesses.
Its ideal for building boxy fuselages for old timers and trainers.. Mathew Follow the SPAD design links in my Flyingboats and Seaplanes- Free plans usefull links thread - most things you can build from correx you can build from this stuff with a bit of imagination .....theres hundreds of free plans out there for SPADS...have a look at Barny and the Spad lazy B.
The wings a bit trickier......needs thinner stuff single or no papper layer...or use Correx.
:regards:Comment
Loads of good info , as usual Clive. Here is an all foamboard Mud Duck by Sandy. Plans for this in 2 sizes plus a crop-duster "Agri-duck" from www.mudduckaviation.com
[ATTACH]14008.IPB[/ATTACH]
