I've started this in response to a question from dubster72 (Patrick) on another thread.
"Actually, maybe someone will answer this one for me-I've noticed that older kits have raised panel lines/rivets & such whereas newer don't. Which is correct? I'm assuming that better manufacturing techniques have improved things but if I fancy making a plane I'd like to get it right."
Older kits tend to have raised panel lines simply because it was easier to cut a mold that way,the mold being a "negative" of the model. I suppose it is modern techniques that makes it easier to cut molds for recessed lines.Panel lines on models are always way over scale. Real aircraft had generally either let in flush skins or overlapping skins.This means that both types can be correct! Either way to scale they would be virtually invisible and impossible to mold. I think both recessed and raised lines can be made to look good on a model. They are only a representation of the real thing. Many joins on the real thing were not easily visible. For example the joins on the frames of the fuselage of a Bf109 (lines much beloved of modellers) were usually puttied and sanded. The front third of a Spitfire wing,including the join between the leading edge and the wing (another line beloved of modellers) was always treated the same way.The entire surface of a Mustang wing was puttied and sanded smooth.
Rivets tend to be overscale for the same reason. Some,scaled up,would be the size of dinner plates! It's each to their own. I tend to go with what's on the model,though I'd like them in the right place (not always the case). I'm too lazy to re-scribe and re-rivet a model.
Real aircraft often had a combination of raised and flush rivet heads as a compromise between smoothness (speed) and ease and speed of construction.
Nothing gets modellers going like rivets and panel lines! I'm in the camp that chooses not to over emphasise them but that doesn't make me right and someone who likes prominent lines wrong. It's just a model.
