I could do with some advice
    Gents
    I'm currently building a 1:72 scale C-47. I've managed to cut out the left side door near the cockpit and now I need to make a ladder. What would be the best way to make this ladder?
    Many thanks in advance
    Regards
    David
    I would have thought plastic rod. You would need to research the ladder for what section the material is in and to get some scale sizes. Alternative would be to use wire of some kind but this would be harder to join unless you can do butt soldering at that size. It may also be worth making a jig of some kind, a block of high density foam or MDF with saw cuts for the rungs of the ladder to ensure the spacing is accurate and, more importantly, consistent to the real thing.
    Having said that, I have never tackled anything like this so there will be better ideas coming along.
    • yak face
      • Jun 2009
      • 13840
      • Tony
      hi david, grahams got it all covered in his answer , plastic rod getting my vote too.One thing though ,would the pilots have boarded through this door so high up or got in at the back door and walked up to the cockpit , i dont know, just a thought , btw try this site its full of fascinating stuff about the dc3/c47http://www.douglasdc3.com/ cheers tony
        Many thanks gents
