Measure the centre of the rod and align this with the built up tailplane,clamp this to the trailing edge of the tailplane as shown,the semi circular end ribs assist the line up operation,whatever you do,do not build the elevators as they show in the magazine unless you want a lot of built in errors and problems !
Issue 64-Assembling one half of the elevator.
Parts included in issue 64 include a shaped trailing edge and single leading edge rod,the way that the parts are assembled in the instructions is asking for problems as there is no guarantee that they will fit the tailplane properly and above all have the correct spacing at the tips of the tailplane,after a bit of thought I devised the following system which utilises the existing tailplane from which the elevators can be built around,also the pre-shaped portion needs a little bending to make it fit properly and if these instructions are followed carefully no problem should arise-
Slip the end rib into place to test fit the item,remove and bevel the rib with a rat-tail file where it accepts the shaped trailing edge piece.
Next slip a piece of card over the rod,adding another piece of card at the front and clamp in place the end rib,this ensures that there is a proper gap between the elevator and the tailplane,apply thin cyno to the joint of the mazak rib.
Next offer up the trailing edge and mark with a permanent marker where the first rib joins the front of the bend,at this stage you will need to adjust the bend to meet the front of the rib itself as it is not accurate as supplied and requires adjusting.
Next add the capping brackets,these can be filed up later as they are far too bulky.
Next add the remaining ribs after first marking the dimensions given in the instructions.
Finally add coldweld fillets to lock everything firmly into place,there is no way that I am going to let this heavy assembly just fall apart after all of this extra work ! everything will be finally sprayed white to replicate the anti-dope white of the full size machine.
When we get the other parts do the same for the other side.
When throughly cured the fillets can be cleaned up and thinned out with a Dremel tool before the painting operation.
