Hi all, This is my first aero-modeling project in over six years and it will be the first time I've used such new fan-dangle things like Putty both Epoxy and out of a tube, cutting and repositioning control surfaces, kit bashing, per-shading, airbrushing an aircraft and shooting enamel paint with a airbrush. Hay I have always thrown my self in the deep end and I'm pretty sure my mum said that I could run before I could crawl
I chose the Bird Dog for this wham up project for a few reasons. First of all I found it in a box old empty boxes when I was look for Airfix flying hours, so I'm treating it like a gift from the kit fairy. Secondly for the sparsely populated cockpit witch will give me a chance to add some detail.
THE BUILD
I have started with cutting and repositioning control surfaces, I cut the ailerons, elevators with trim-tab and rudder. I left the flaps as they looked like they would be a lot of work for me. Even I know when not to bit off more then I can chew. At the same time I filled the holes in the main wings surface and re glued the ailerons
Moving on to the cockpit. I used some Green Stuff to sculpted the quilted looking insulation on the cockpit interior. I found a spear P51 seat from a build I done many years ago which with a bit of cutting looks a lot like the photos I have found. I added a control stick and some bits and pieces where the fuel selector valve is located as well as a second control stick in the stored position on the side wall between the two seats.
THE BUILD
