Hello everybody this is my first post, and boy im starting off with what may be newbie questions but any help that can be given to me would be greatly appreciated! I hope I am posting this in the correct section of the forums.
So here goes:
I have purchased a Tamiya 1/48 Hawker Hurricane mk.1 Plastic Model.
Unfortunately I do not have an airbrush so I am going to have to handbrush the entire model, I was planning on using a spraycan grey primer on the entire model prior to painting. When it comes to painting I am going to use Humbrol enamel paints, here comes my first question - Will I need to thin the paints at all to avoid brushstrokes as much as possible? and are there any good ways to handbrush the camo to avoid harsh lines where the two camo colours meet?
After painting camo etc I was planning on using the Humbrol Glosscote on the model, letting that set and then applying the decals with Microscale Model Sol and then setting with Microscale Model Set, I was then planning on using a wash for shadows and panel lines etc and then a very light amount of drybrushing on raised areas and possibly slight pencil weathering.
When satisfied I was then going to finish the entire model with Humbrol Mattcote.
It all sounds very good in my head but the reality is I may have issues with solvents in the varnishes etc reacting to the enamel and other products used.
So my overall question is would this plan of attack work and have I got the order of the applications correct? I have seen so many techniques with pros and cons to each and what started off as a "simple" model build has turned into a full operation with military precision.
Thanks for any help or replies that I get.
So here goes:
