ISSUE No.100-The Cowling and bush.
Well the cowling has finally arrived to complete the front end of the model,one bush and not two has been supplied,this fits inside the front cowl opening and supports the heavy rotary engine,just make sure that the cowling has been well araldited onto the front former,with the propeller I would like to have seen a lot longer main shaft,this area looks vulnerable to getting knocked off.
The whole model weighs a ton so make sure that when you lift her up,do so from ther bottom of the fuselage,all of those struts need attaching securely.
__________________________________________________ __________________________________________________ __
