Hi all!
An appeal for help as I am failing with Google etc...
I am tackling a French AD-4NA and one feature I want is a correct 300-gal drop tank. The French used a pressed steel model that had a horizontal seam, unlike the standard 300-gal type used by the Americans. It is also a little more dumpy. My problem is that I can't find any references to it and certainly no thoughts as to the best source if I was to scratch build from another kit.
I'd welcome your wealth of knowledge and guidance. Thanks.
Martin
Martin
