Russet...
    Russet...
    I'm reading the instructions of a spitfire MK IXe, my next build, and I have to paint the pilot "chair" with this colour... I don't have it in my stage... Someone knows if it's more similar to red or like red/brown?
    Thanks
    Polux
      • 18266
      Red brown will be fine. I use Vallejo mahogany with a drop of red.
      you want to try for a chestnut colour (de color castaƱo)
      The 'red seats where made from a plastic material so no metal chip marks either!
        • 22770
        Vallejo 70.818 Red Leather is close Polux
          Thank you very much guys!
          • stona
            • Jul 2008
            • 9889
            Polux, most native english speakers would be unsure of exactly what colour "russet" is. It's an old word for a brown/red colour, often used to describe autumn colours such as the leaves on the trees before they fall.
            You won't go far wrong with Edgar's photo.
              • 18266
              Oi! you saying I'm old LOL
              • stona
                • Jul 2008
                • 9889
                You can't be that old! According to the online etymology dictionary the word has origins in old French and was originally a reddish-brown cloth. It has been used as an adjective since the 14th century. It was applied to a type of apple in the 1620s and a pear in the 1720s, but I doubt you remember that either
                The application to a red-brown colour has remained consistent for about 700 years which is good going for any word!
                  • 18266
                  Nah not that old but old enough to know what it means and use it
                  • eddiesolo
                    • Jul 2013
                    • 11193
                    Yep, the seat was made from a Bakelite type plastic.
                    Si
                      Thank you 'old' guys...
                      Steve# in a few days will open the thread, and will try to do a complet one! Similar your fantastic ones!!
                      I'm happy, I know, there is very friendly members if you need help
                      Thanks!
                      Polux
                      • eddiesolo
                        • Jul 2013
                        • 11193
                        Just to add that the early Spits had a metal seat in green, from May 1940 they had the fibre/bakelite ( actually, it is SRBP-synthetic resin bonded paper) russet coloured one. There was a issue with the bonded strength of the seat prior to that date. This seat was moulded so technically it isn't Bakelite as the granular plastic takes a controlled heat and immense pressure to form and cure properly hence the use of Resin Bonding. The same seats were fitted in many aircraft, Hurricanes, Vampires etc.
                        Si
