Does anyone know if it's possible to buy those clear plastic aircraft stands on their own (you know the things I mean, they probably have a really technical name like a flagimgabar or something). I have an idea for a future plane build with the plane in flight and wondered if these can be bought separately or if it's a case of buying a kit and hoping for the best.
Aircraft stands
Italeria make a set of 2 for ยฃ5, just google it and you should find them, i know model hobbies sell them.Comment
Simply heat it up in a pan of boilng water and gently bend it. Take your time and don't try to bend it as it cools or you will definitely break it! I keep one end in the boiling water and push gently against the side of the pan. I hold the other (cold) end in a pair of long nose pliers as there is a definite potential of a scolding in the steam. It takes a bit of trial and error to get the angles as you want but you can keep reheating and bending as much as you need to. You can set the angles to suit.
Here's a bad photo of a diving and turning Bf109. Same type of stand.
Theuns that's Xtracrylix RLM78 on the lower surfaces.Comment
Going totally back to basics here - where would you actually *get* the rods (and bases for that matter) from generally? They look great, would love to have a go at making one. Cheers!Comment
Originally posted by \Going totally back to basics here - where would you actually *get* the rods (and bases for that matter) from generally? They look great, would love to have a go at making one. Cheers!
SteveComment
Originally posted by \They're very neat Steve. Do you just omit the blades? It looks very effective
Having watched aircraft screaming past at various air shows I find the propeller disc to be virtually invisible. I don't think that static blades look good on a model posed in flight.
My next "inflight" model,some way down the line, will be an Me262,the only jet I ever build. No need to worry with that one.
SteveComment
just had a look at the propblur website and they look very effective,dont imagine it would be very hard to make your own though.Comment
