Going big
    Going big
    I was lucky to be given this 1/24 Heller (Airfix) JU 87 B2 kit yesterday. It might be old but the decals and the moldings actually still look very crisp, I understand that it builds into a very nice model straight out the box :-)
    Theuns
    [ATTACH]75890.IPB[/ATTACH]
    • 22770
    I do like the Stuka, looking forward to seeing what you do with this one Theuns
      The focal point of such a cracking kit has to be the huge canopy and the detail that you can cram into it. The fact that you were given it will make it all the more enjoyable to build as well!
      • stona
        • Jul 2008
        • 9889
        Hi Theuns, I built all the Airfix 1/24 kits many moons ago and in my opinion the Ju 87 was the best of the lot.
        If there is a temperate option in the box and the colour call still shows a one colour green upper surface it's wrong !
          Thanx guys,
          Steve, yes it does show a France 1940 all gree, I did think it was wrong.
          I will give you the sqn codes and maybe you could point mi into the rite didrection re the correct scheme.
          I assume it would be a standard splinter camo?
          Were there any airframe differences between the trop and the mainland ones?
          Theuns
            The trop is A5#BH and the "green one" is T6#KL.
            A little more info would be very welcome.
            Thanx
            Theuns
            • stona
              • Jul 2008
              • 9889
              Originally posted by \
              The trop is A5#BH and the "green one" is T6#KL.A little more info would be very welcome.
              Thanx
              Theuns
              T6+KL would have been in the standard splinter scheme.
              The markings would be for 3./St.G 2 at a guess. T6 is definitely StG 2 anyway
              A5+BH was from 1./St.G 1. There is a picture in one of Smith's books of this aircraft in flight. Of interest is that it too is in the normal splinter scheme. The white individual aircraft letter is repeated on the upper surface of the wings. I have other pictures of aircraft from this unit which have had tropical camo applied (A5+HL and the wreck of A5+EL) so it must be possible that A5+BH also got repainted in a tropical scheme.
              The two aircraft are actually a B-2 (T6+KL) and an R-2 (A5+BH) but externally they are so similar that you can build both from the kit. The R-2 had more internal fuel tanks and could carry under wing drop tanks.
              • The Migrant
                • Apr 2011
                • 1268
                That's a useful camo diagram Steve, which book is it from?
                • stona
                  • Jul 2008
                  • 9889
                  I scanned it years ago. Maybe Merrick or Ullmann ?
                  Edit. The same diagram is on p 84 of Eddie Creek's Ju 87 book too.
                  • The Migrant
                    • Apr 2011
                    • 1268
                    Thanks Steve.
                    • saguy
                      • Feb 2011
                      • 570
                      hi theuns ... will keep a close eye on this one ...just finished a 1/48 version and it's a great looking aircraft once finished ..... cheers
                      lindsey
                      • flyjoe180
                        • Jan 2012
                        • 12390
                        • Joe
                        • Earth
                        This will be a cracking build Theuns, lucky chap.
                          Thanx Steve, I don't think I could ask for anything more exact as that! :-D
                          Hard or soft edges on the demarcation lines?
                          Lindsey, where you based? I am up in the "big smoke" JHB.
                          Theuns
                          • saguy
                            • Feb 2011
                            • 570
                            Thanx Steve, I don't think I could ask for anything more exact as that! :-DHard or soft edges on the demarcation lines?
                            Theuns
                            Hi Theuns .... same town .... right by northgate ... i end up paying the aviation shop and esswex regular visits ... cheers
                            • stona
                              • Jul 2008
                              • 9889
                              In 1/48 it's going to be a hard. I've never heard it said that masks were used in the factory, rather that diagram I posted was used to mark out the scheme which was then sprayed. A good sprayer can achieve a very tight demarcation.
                              The contrast between RLMs 70 and 71 was very low. Most modellers make it more visible than it actually was. This makes it quite difficult to even see the demarcation in many black and white photographs, but here's a couple where it is visible.
                              I think that in the first image you can see where the outline of the pattern was sprayed before being filled.
