Thinking of going over to the dark side!
    Hi all,
    I need some advice from the aircraft builders! I'd like to try an aircraft kit & I was thinking of this one :
    [ATTACH]79191.IPB[/ATTACH]
    Does anyone have first-hand experience of this one?
    Thanks in advance
    Patrick
  • spanner570
    • 15402
    Patrick, to get your eye in, would it not be better to go for a smaller scale?
    There again, I'm sure you will make an excellent job of it - whatever scale!
      Well, I was thinking that this is closest to the armour scale that I'm used to - I think 1/72 would be too small for my clumsy fingers!
      But maybe a practice run on one of the new airfix kits might be a good idea
      • stona
        • Jul 2008
        • 9889
        It's a newish and good kit. There are one or two little things to be aware of but nothing difficult or hard to fix. It is also an accurate model of a Bf 109 if you are worried about that.
        As you are hardly new to modelling I don't see why you couldn't build this kit. I think almost all the skills from the different modelling genres are transferrable.
          Cheers Steve, that's what I'm after really - something without too many nasty surprises like needing huge amounts of filler!
          I think it's time to place an order ...
          • tr1ckey66
            • Mar 2009
            • 3592
            The kit is very good with great surface detail. The front cowlings are separate parts (to allow for further 109 variants) so will need careful assembly but the kit is well engineered and shouldn't present any probs.
            Question: is 1:32 the new 1:48?!!!!!
            Have fun
            Paul
              That's a good point Paul, & knowing me I'd end up with an early front & a late rear! Iuckily there's a very helpful review I've found, so that will be an invaluable guide.
              • stona
                • Jul 2008
                • 9889
                And if you're not sure of which options go with which version (silly little things like the oil filler points) you can always ask here
                  Ha-ha cheers Steve, I can foresee a series of silly questions coming once the postman delivers the box!
                    • 18269
                    Dont feint but I have bought the self same kit! I will be watching to find all the traps before I start mine !
                    The biggest challenge you will face, going over from armour, is the paint colours. Oh and masking cockpit canopies....
                    • AlanG
                      • 6296
                      Patrick you can also turn this kit into a G14 with very few little tweeks http://forum.largescalemodeller.com/topic/1238-132-messerschmitt-bf-109g-6-early-and-late/
                      • stona
                        • Jul 2008
                        • 9889
                        That is a good guide, at least as I flicked through it, and answers most of the questions I'd expect about the various versions of the G-6.
                        There were a lot of variations and no real standard production G-6. The G-14 was a failed attempt to consolidate the various changes adopted throughout G-6 production into an updated standard. By the time this was attempted circumstances, not least the allied bombing, were making supply chains unreliable and aircraft tended to be built with available components and engines, any standard going out the window.
                        Along with 'what colour were Spitfire wheel wells?' the question 'when does a G-6 become a G-14?' is one of those universal imponderables
                        • yak face
                          • Jun 2009
                          • 13841
                          • Tony
                          The force is strong in you , embrace the dark side Lord Patrick! Its a great place to start Patrick , and at 1/32 its a nice manageable size too. As has been said its a newish tooling and got favourable reviews when released , and if its anything like most of Revells recent stuff it should be nicely detailed, well fitting and with excellent decals. Looking forward to seeing this one under construction , cheers tony
                            Allyne thank you, that's a great link so it's bookmarked for future reference
                            Ha-ha we'll see how strong the force is when I'm staring blankly at wing assemblies & cockpit parts!
                            But I've dabbled with some Revell armour, so I know they're usually a decent fit
                            Cheers Patrick
                            • BarryW
                              • Jul 2011
                              • 6027
                              This is where it starts Patrick - you dable with a Revell 109G, then next the Tammy Mustang/Corsair/Zero/Spitfire superkits leading to a stash of a dozen Trumpy and Hassy 1:32s..... a small step then a giant leap. Welcome to the dark side...........
