57’ Bel-Air
  • Jukebox64
    • Aug 2024
    • 161
    57’ Bel-Air
    Just a few pics while waiting for paint to dry. Click image for larger version
ID:	1239487 Click image for larger version
ID:	1239486 Click image for larger version
ID:	1239485 Click image for larger version
ID:	1239484 Click image for larger version
  • Jukebox64
    • Aug 2024
    • 161
    Well, I tried to clear this paint job with a rattle can and it totally ruined my paint job. So I sanded it down and started it all over.
    • Steven000
      • Aug 2018
      • 2816
      • Steven
      • Belgium
      Paints can react heavily sometimes, I don't do it enough myself but it helps to spray test-pieces (old plastic cards) to test for any reaction...
      Hope you'll have better luck next time ? cheers
      • Jukebox64
        Jukebox64 commented
        Editing a comment
        I usually do that too with spoons, but I’ve done this clear before and it turned out fine. Like I said, it’s my own fault because usually I put about three light mist coats of clear on the model before I do my last wet coat. But this time I only used two light missed coats and got excited and put the third one on wet without paying attention. Now the body is completely ruined and I have to get another one and start over. Also, I think I’m using the wrong paint remover..
    • PaulTRose
      • Jun 2013
      • 6406
      • Tattooine
      Thats a nice colour
      Is it going to be stock or custom?
      Per Ardua
      • Jukebox64
        • Aug 2024
        • 161
        It’s a custom build,and thanks.
          • 15595
          Strange and very annoying when you get a bad paint reaction especially when there was no real reason for it. Sometimes it could be the under paint not fully cured or maybe even very high atmosheric humidity but often it just happens and you just don't know why. Hope the second attempt goes well.
          • Jukebox64
            • Aug 2024
            • 161
            Trying to strip the paint I screwed up the body so bad that I had to order a whole new model just to get the body.?
            • Jukebox64
              • Aug 2024
              • 161
              Can anyone tell me the best way to polish tape residue off of the paint?
              • flyjoe180
                flyjoe180 commented
                Editing a comment
                You could use a polishing compound (or toothpaste if you prefer mint).
            • Jukebox64
              • Aug 2024
              • 161
              It’s coming along nicely. Click image for larger version
ID:	1241145 Click image for larger version
ID:	1241144 Click image for larger version
ID:	1241143 Click image for larger version
ID:	1241142 Click image for larger version
              • Steven000
                Steven000 commented
                Editing a comment
                The new body looks very nice Jukebox, careful now! ??
            • Jukebox64
              • Aug 2024
              • 161
              I don’t know why I guess it was just my method, but I used the exact same type of paint and clear and this time it all came out great.. I put six dry coats of clear with a drying time of 20 minutes in between each coat before I put two wet coats of clear on. Plus, I waited about an hour between each wet coat.
              • Jukebox64
                • Aug 2024
                • 161
ID:	1241376 Click image for larger version
ID:	1241377 Click image for larger version
ID:	1241378 Click image for larger version
ID:	1241379 Click image for larger version
ID:	1241380 Click image for larger version
ID:	1241381 Click image for larger version
ID:	1241382 Click image for larger version
ID:	1241383 Click image for larger version
ID:	1241384 Click image for larger version
                • Steven000
                  Steven000 commented
                  Editing a comment
                  Apart from all the paint-troubles this turned out really nice ? well done. You can still make a rustbucket-version with the 2nd kit you bought ? cheers
