Hi all. Picked this up off Flea-bay cheap as it had already been started. The engine block and gearbox had been glued together, which was fine, but the instrument panel and gear lever had also been installed, which might not be so fine.....we'll have to see.
So, all I've done so far is assemble a few more bits and start detail painting. I'm hoping to add add a few more details, mainly plumbing and electrical wiring, and I think I'm going to split the bodywork, fixing the front end ( as the fit isn't brilliant, and it'll save a bit of work !!) and leaving just the rear part removable. I'm also going to try and add the rear diffuser, which is strangely missing...???
Anyway, this is the work so far....
[ATTACH]84205.IPB[/ATTACH]
[ATTACH]84206.IPB[/ATTACH]
[ATTACH]84207.IPB[/ATTACH]
[ATTACH]84208.IPB[/ATTACH]
[ATTACH]84209.IPB[/ATTACH]
[ATTACH]84210.IPB[/ATTACH]
Cheers, Neil
Cheers, Neil
