1/8 D Type Jaguar scratch build
    Many thanks for the kind comments.
    Yes, the engine is scratch made also, using a few Revell 1/8 E Type engine parts as a master.
    I took moulds from the main bits - block, head and cam covers - and cast the bits in resin.
    All the other parts are scratch as the D Type engine has a lot of differences to the E Type. Making the dry sump was a challenge...
    The tyres are solid resin too. I made a mould from an E Type tyre filled with plasticine, made one in resin, then sanded off all the text, raised lines etc to create a generic tyre.
    That one was moulded, and resin ones taken from that.
    They are painted with Tamiya rubber black.
    Roy.
    • takeslousyphotos
      • Apr 2013
      • 3900
      #32
      I only just caught up on this Roy ......... Absolutely amazing stuff. I am in total awe of your work. Even 'er indoors (who thinks making models is stuff that 12 year olds should be doing with airfix kits) was impressed ........ and that, matey is a serious accolade.
      Amazing.
      Peter
        Originally posted by \
        Many thanks for the kind comments.Yes, the engine is scratch made also......
        Roy.
        Astounding! If you ever have heart problems or lost a leg, you could just scratch build a perfect replica! Astounding!
          Seriously kind comments you guys. Many, many thanks.
          The big D is getting there, but next is the windscreen and surround......
          Roy.
          • Marc Stock
            • Jan 2015
            • 664
            #35
            How did you cast the parts?
              My casting???
              Have a peep here....
              http://www.britmodeller.com/forums/index.php?/topic/234972754-moulding-and-casting-your-own-parts/
              Roy.
                Thanks for that. A complete tutorial. I have filed it away for future use. It would be interesting to experiment to see how deep hollows would be successful.
                I think it should be moved to the Tutorials and How-tos topic.
                  Wow.
                  That is all
                  • Marc Stock
                    • Jan 2015
                    • 664
                    #39
                    Thanks Roy.
                    • flyjoe180
                      • Jan 2012
                      • 12481
                      • Joe
                      • Earth
                      #40
                      Outstanding work Roy, great progress.
                        Time to get this one finished.....
                        A template has been made for the windscreen.
                        Next - try it in acetate OR clear poly......
                        Roy.
                        [ATTACH]104058.IPB[/ATTACH]
                          Getting there now......
                          Roy.
                          [ATTACH]105951.IPB[/ATTACH]
                          [ATTACH]105952.IPB[/ATTACH]
                          [ATTACH]105953.IPB[/ATTACH]
