Well I have to say I am thinking I have bitten off more than I can chew, been adding the rivets and nuts to the mud guards, spent all night doing one mud guard (I thought this would be an easy detail ) how wrong I was and stupidly I ordered the wrong size acorn nuts for the engine, I ordered m2 thinking that was the outside measurement but it was the thread size so they are massive, no idea what I will use them on.
Airfix 1/12 4.5 liter Bentley
Hi all here is all day and most of last nights work.
[ATTACH]97186.IPB[/ATTACH]
[ATTACH]97187.IPB[/ATTACH]
[ATTACH]97188.IPB[/ATTACH]
[ATTACH]97189.IPB[/ATTACH]
[ATTACH]97190.IPB[/ATTACH]
[ATTACH]97191.IPB[/ATTACH]
[ATTACH]97192.IPB[/ATTACH]
[ATTACH]97193.IPB[/ATTACH]
Hi all not sure how I am going to remove the stubs from the rivets but I'm sure I will find a way before they are needed.
[ATTACH]97263.IPB[/ATTACH]
Anyway here is todays progress.
[ATTACH]97264.IPB[/ATTACH]
[ATTACH]97265.IPB[/ATTACH]
[ATTACH]97266.IPB[/ATTACH]
[ATTACH]97267.IPB[/ATTACH]
[ATTACH]97268.IPB[/ATTACH]
[ATTACH]97269.IPB[/ATTACH]
[ATTACH]97270.IPB[/ATTACH]
[ATTACH]97271.IPB[/ATTACH]
[ATTACH]97272.IPB[/ATTACH]
[ATTACH]97273.IPB[/ATTACH]
[ATTACH]97274.IPB[/ATTACH]
[ATTACH]97275.IPB[/ATTACH]
[ATTACH]97276.IPB[/ATTACH]
Wow loving that rivet work, looking very tidy. How did you do the detail on the leaf springs? id be very interested to learn how to do that.Comment
Hi Marc I used rigging yarn superglued the first bit near as I could to the root of the spring then spread a thin layer of pva glue over the rest of the spring and, keeping the yarn tight wound it round the spring till I got to the other end then a little dab of superglue just to keep it in place till the pva sets.
Hope that helps.Comment
Hi all got a fair bit done to the figures (post pics tomorrow ) sorry moni not up to your standards, any tips greatly appreciated.Comment
Hi all here is tonights update, I made the mistake for deciding to replace the plastic spokes with real ones, I am going to live to regret that decision
[ATTACH]97540.IPB[/ATTACH]
[ATTACH]97541.IPB[/ATTACH]
[ATTACH]97542.IPB[/ATTACH]
[ATTACH]97543.IPB[/ATTACH]
Hi all well here is half of the first wheel spoked(yes I know its not pretty) but lessons learned and it can go on the side nearest the wall in the dio so wont be seen.
[ATTACH]97609.IPB[/ATTACH]
[ATTACH]97610.IPB[/ATTACH]
and here is some progress on the car
[ATTACH]97611.IPB[/ATTACH]
[ATTACH]97612.IPB[/ATTACH]
Hi all here is tonight's bit. I have cut off the steering column (not my idea got it from stevieo) and replaced it with part of my extending mirror.
[ATTACH]97701.IPB[/ATTACH]
[ATTACH]97702.IPB[/ATTACH]
[ATTACH]97703.IPB[/ATTACH]
and here is more progress on the rest[ATTACH]97705.IPB[/ATTACH]
[ATTACH]97706.IPB[/ATTACH]
[ATTACH]97707.IPB[/ATTACH]
[ATTACH]97708.IPB[/ATTACH]
[ATTACH]97709.IPB[/ATTACH]
[ATTACH]97710.IPB[/ATTACH]
I understand these car bodys were covered with cloth and am thinking of covering it with paper and painting that, do you think that would give a clothe effect finish.
Originally posted by \Hi all well here is half of the first wheel spoked(yes I know its not pretty) but lessons learned and it can go on the side nearest the wall in the dio so wont be seen.
Here's an idea; drill the hole in the rim, cut the wire for the spoke at an angle and 'drill' that into the hub. hold the wire in a pin-vice.
Those front seat's look very good.
Ian MComment
