Originally posted by \
Tamiya Mercedes Benz 300sl 1/24
Thanks guys for your kind words. Dave your question about rub through, well thats just it your rubbing it and thats where your going wrong.
I prefer to think like im 'cutting' it. When you wet shave do you apply pressure like your rubbing? Of course not you go lightly and let the razor cut.
Its the same with micromesh, you need just enough pressure to hold it against the surface (this means no pressure really, like your holding a butterfly wing). Dont rub it back and forth like your sanding something, go in light straight cuts from left to right and count them. I did 40 cuts before moving up to the next grade ( this varies from one person to the other), as you go up to the next grade it will take less off. Also listen to the cut, if its scraping like your sanding something your going too hard. You want to listen for a high pitch squeeky sort of rizzle sound (is the best i can describe it ) and make sure you do it wet to keep friction heat down. Use lots of water, too little and the paper will 'grab' the paint and graze it ( especially on freshly dried paint ) and take your time dont rush it.
I did one panel at a time divding up the sections. This ensured i didnt go uneaven on one place.
Don't know if that helps or notComment
Originally posted by \That's a thing, how do you stop rub through when using micromesh? It's a problem I had on my cobra.
Next you use finer micromesh than you want to... If you go too course you have deeper scratches to remove from the paint but you have already removed a lot of the overall thickness by then. You just want to remove the orange peel to a desirable level with the finest grit you can get away with and then use compound for the shine.
Stay away from edges and corners where possible as they get rubbed down more and the paint tends to be thinner.
Mark has done an exceptional job on this, his patience and pace seem to be spot on.Comment
Oh and you want to feel like the mesh is sticking. That's when it has done is job and made a smooth flat surface for that grade of mesh. Well it seems to for meComment
Good advice there Dougie. What do you think of the new wheel combination?
[ATTACH]124232.IPB[/ATTACH]
[ATTACH]124233.IPB[/ATTACH]
Looking great mate, they set it off really nicely, this will look amazing on display on a shelfComment
Originally posted by \Is not easy. You need to get a really even coat of paint all over without going too thick.
Agreed, Marks work is flawless.Comment
Originally posted by \Thanks guys for your kind words. Dave your question about rub through, well thats just it your rubbing it and thats where your going wrong.
I'm also preparing a Ferrari Enzo, got this from a charity shop today, it was already built, the body looked as though it had been painted by Stevie Wonder using a very large hairy stick, the interior is reasonable, looks like it may have been a joint father/son venture. Stripped it down today, paint has been taken off, lost the decals though (might present a problem for me ), only cost me £2 so no risk if I have to bin it!Comment
Flip me guys. My work isn't flawless, but I appreciate the sentiments really I do. I'm just a modeler learning as he goes and enjoying the journey. Like you all.Comment
Well i have some bad news and then some good news. The bad news is I have another pinger. The brakelight lense that i painstakingly painted pinged off the bezel when attaching with tweezers and lost it.
The good news is that i found something on the bottom of my foot (i rarely wear socks at home) and it was the pinged off indicator lense i lost a few days earlier. Lol
Then popped it in the model happy ish and went to take a break and something else stuck to my foot...yep the brake light lense. Hahhahaha
So now I don't have to order another kit to complete this one. Yay for now..but im still buying another one anyway for the barn find build.
[ATTACH]124380.IPB[/ATTACH]
[ATTACH]124381.IPB[/ATTACH]
[ATTACH]124382.IPB[/ATTACH]
[ATTACH]124383.IPB[/ATTACH]
[ATTACH]124384.IPB[/ATTACH]
Ok chaps.
The time has come. The build has entered its final dressing stage. Im happy with the model so far, only thing thats bugging me is the window surround. Its ok, but the rest of the bodywork is so perfect it looks gash in my opinion.
So im going to go down the bare metal foil route on windows surround, I can't leave the model completed with painted window surrounds its just going to annoy the hell out of me with all the effort put in.
Here is the model and its current stage of finish. All i have to do is metal decals on boot, the Mercedes name on the side, permanently fix the doors into the hinges, add the wing mirror (got to make a hole) attach the window wipers, and bare metal foil the window surround and install glass.
The next post will be of the completed model.
Thank you so much for following this rather long thread, you have all added enjoyment to this build for me and I thank you all for your input and support.
Next new build is the barn find 300sl. And im also in possession of an Aston Martin that my dad bought for me a few weeks back as an anniversary present. (Thanks daddy)
[ATTACH]124460.IPB[/ATTACH]
[ATTACH]124461.IPB[/ATTACH]
[ATTACH]124462.IPB[/ATTACH]
[ATTACH]124463.IPB[/ATTACH]
[ATTACH]124464.IPB[/ATTACH]
[ATTACH]124465.IPB[/ATTACH]
[ATTACH]124466.IPB[/ATTACH]
[ATTACH]124467.IPB[/ATTACH]
I would be so chuffed with this mate. Top work. Hope the bmf goes well. Also how did you do the clear paint on the lenses? Brush? How many coats etc.. I find those tricky to do well with tamiya paint. Maybe impatient.
CheersComment
Thanks Dougie. Yeah the light lenses were very tricky. I find its better to blob it on as if you paint it on it just streaks across the acrylic. The hardest part was getting the lenses to fit inside the bezels and getting them to lay flat whilst manipulation. A blob of clearcoat on the underside acted as a glue to keep them in place.Comment
