thanks ian and all off you. Please help last pic that I have just put on tonight, the engine part does not match together right, it is the thickness of the metal ruler that's how much it is out, but enjoy any way.
[ATTACH]270794[/ATTACH] [ATTACH]270795[/ATTACH] [ATTACH]270796[/ATTACH] [ATTACH]270797[/ATTACH] [ATTACH]270798[/ATTACH]
It's a Tamiya kit Jim so fit will be perfect, always test fit first so you know your putting it together the way it should go, can you get it apart and try a different position, tamiya kits don't have fit issues. Are you sure there is not a piece goes over that to hide it .
Ken I have taken it apart and test fitted it and it is still the same. The other parts fit ok in dry test ok it's fine there groves for back off engine me was confused
