Italeri 1/12 Fiat Mefistofeles
    Thanks marc its not paint its the actual metal, it's brass leaf, I have copper leaf for all the pipe work.
      Hi all I've just realised there is a huge error on this engines valve gear, every single cylinder is moulded in compression stroke (all valves closed) every multi cylinder engine I've ever worked on whilst one is closed the other is either on exhaust or intake stroke, had I have noticed before I'd brass leafed or stuck them on I could have corrected it fairly easily I think, too late now but for anyone else building this a point to remember.
        Hi all well as I'm doing this as she was for the record run I've primed her in black(she was painted red some time after she went into the museum, on the run she was black)
          Hi all well done a bit more on this, I was told by someone building this on another forum the chain is very difficult to do(you put it together in sections then melt the little pins to keep the chain together)
          well as he did I melted the first link to the one underneath, so I had a rethink activexp (the other builder) tried a solering iron with adjustable heat setting and even on the lower setting had trouble with melting links so that method I ruled out, my solution which seemed to work quite well after a few minor changes (tried cold water but cooled the blade to quick)I put the chain assy in a shallow glass dish and put just enough hot water in till it is level with the top link then heat the knife blade up and melt the pin, I made the water as hot as I could bare to put my hand in (not boiling as was worried it might warp or melt the plastic)
          this is just one set there are I think 4 more
            • 22770
            #35
            Your doing some great work on this Ken
              Hi all thinking of giving up this modeling lark but will finish what I've started and the Rolls,tbh i just don't have the time and apart from the loyal few no one is really interested in what i'm doing, anyway here is where i'm at on this .
                Don't give up, just because people do not comment does not mean they are not interested. Usually, it just means they have nothing to say or add to what has been said.
                Modelling is a hobby for your own enjoyment and interests. Nobody should model to please others the aim is to please yourself. The amount of work you put into your models is amazing. Who else would use brass leaf rather than just paint? I wouldn't even know how to do that. You add so much to a kit to make it how you want it, that to me is real modelling, I just build kits but I build them for myself. It can be dissheartening when you post an don't get comments but that is the nature of forums. There can be hundreds of members but generally the majority of posts come from a couple of dozen at the most.
                That couple of dozen will not be interested in everything as a subject and so some may never comment. But they still take something from what you do and it is that sharing of skills and techniques that makes forums like this so valuable.
                What you give by showing your work is a big asset to everyone so please keep it up.
                  Thanks Graham its time that is the real problem, if you look back I used to post practically every day, and enjoyed it, now, it seems, I'm lucky if I get 2 days modeling a week, and I can only see it vetting worse, it's terrible I'm like an addict and it is so frustrating wanting to build every day and not being able to.
                    I certainly know that feeling. Things have changed in my life that allow me to take a more relaxed attitude to modelling, and everything else for that matter. Generally though, it is a few hours at the weekend and maybe an evening in the week. I needed for my own sanity to make that time as I was closing down everything I did and I now can achieve things in weeks that I just could not achieve at all.
                    Modelling has been one of the best relaxing, even when it gets sooo frustrating, hobbies I have ever had. I know one guy, have met him at many shows and he is not on this forum. He builds the most amazing models yet he never touches them in the week, he just has so many hours at the weekends. Once he accepted that this was his lot, he got into the routine and built museum standard models, maybe only a few per year but he still does it.
                    I have learned the hard way that it is not about the amount of time we can get, it's about what we do with the time we have. Plan your modelling around what time you can get and forget about everything else.
                      • 22770
                      #40
                      YOU CAN'T give up Ken, what inspiration would us lesser mortal have.
                        • 22770
                        #41
                        Oops forgot to add great work Ken keep it up
                        • Marc Stock
                          • Jan 2015
                          • 664
                          #42
                          I agree on the comments above. I haven't been able to get any more time on the aston build, two young kids, two businesses to run i just do what i can when i can. In fact i prefer it this way as im more inclined to take my time when i actually do get some time on the bench. Ken please dont giveup.
                            Hi all I did say I would only do a start and finish post, but this is such a big build, and I get so little build time now that I think I will post an engine finished post probably tomorrow, if not it may be months, or in the case of my ship builds years before I post any more progress builds
                              Hi Ken,I've just found this post but as I know next to nothing about plastic kit modelling I can't really post any other comment apart from it looks brilliant and keep it up.
                              The majority of models on here are unbelievable in the quality of workmanship and I would one day love to be able to be half as good.
                                Hi all well engine is done, I've put the body shell on just for fun (don't worry it won't be that shiny when finished, I'm going to rub vasline over it
