Hi all well now the big Citroen is done I've promised myself I will finish this to add another stalled build to the finished pile.
I'm not sure why I put the engine in the chassis as it was not finished there is some pipework I hadn't added as you can see from this first pic
I really like the wheels on this kit, although they are a bit too shiney.
I think they look better now.
Hi all here's the next update the four breather holes in the hood were added after the speed run so I've filled them
The next problem I thought I might have was that the name mefistofeles is in black and with a black car obviously I would need to make a negative of it, however luckily enough the name was added after the run so it is not a problem after all.
The lettering was stark white so I've dulled it down a bit
Need to do a bit more research apparently it may have had 2 seats in the record run.
Hi all there would have been quite a big update on this, I'm starting to wonder if there is somthing wrong with me, I dropped it (this must be a dozen I've dropped in the last year) thing is I don't know why I dropped it I was about to put a screw in and next thing I knew it was on the floor (fortunately not too much damage ) but some thin bits of plastic may need replacing with copper wire, I'm starting to worry maybe I've got dropsy or something.
Hi all here's an update on this, I think the kit exhaust is toooo shiney,
Sooo, mask up the exhaust straps
Spray with hairspray then sprinkle talcum powder on it
Respray with hairspray and then sprinkle on some salt
I think it looks much more realistic now
Looks really nice, i like the tip on texturing the exhaust. Ive just bought some texturimg powder and glue from a new polish (i think) company but i will keep this in mind too
