[ATTACH]276600[/ATTACH]
Battered box, instructions like an old newspaper and decals that look decidedly dodgy....
Not sure how long this has been in the shed but it must be a couple of years. Cannot even remember where I got it from but I decided it was time it was built.
[ATTACH]276595[/ATTACH]
As you can see, not many parts but the flash is terrible and look at the 'T' bars sticking out the back of the body and the fuel tank! When you get sprue attachment points half an inch wide or more, you know it is going to be trouble.
Tons of chrome with half that weight in flash. There is no way you could use a lot of these parts without taking the chrome off to clean them up. As always, I just stripped it anyway
However, once you get past the cleaning up of the parts, this is a delightful little kit. As usual for me now, the body was prepped, sprayed and left to cure while I started on the chassis. The sweet little engine is quite good.
[ATTACH]276596[/ATTACH]
Then, with the body paint dry, I test fitted it to the chassis.
[ATTACH]276598[/ATTACH]
Happy that everything was fitting as it should, I added some lead wire HT leads painted green and then I clear coated the body, bonnet and chassis. OK, the chassis didn't need it but I mixed too much so I used it lol.
[ATTACH]276597[/ATTACH]
Then, I plonked the body loosely onto the chassis when it was touch dry and put it to one side to fully cure for the next 24 hours or so.
[ATTACH]276599[/ATTACH]
To get an idea of the shine, have a look on the side door, you can see the reflection of the lines on the cutting mat.
More to come......
More to come......
