That's coming together lovely, the carpet looks good
Tamiya Morgan 4/4
Thanks,
I should have marked out and painted the trim at the back before the bodyshell was fitted to the chassis, but you always think about these things after the event !
However I painted them this morning and it went a lot better than I had anticipated.Comment
When I masked off the bodyshell to paint the bulkhead black, I also airbrushed the inner wings, but because the way I masked off, I didn't paint the rear part of the under body, so that was done using Humbrol black acrylic brushed on, the exhaust was fitted and the rear valance and bumper bars were fitted at the same time, the front grill was a little bit tricky to fit, as I had fitted the grill surround at the beginning of the build before I had painted the bodyshell, but this should be fitted later in the build, but it's worth fixing it on before painting as it makes for a cleaner build, the bonnet panels were simply clipped into place, the wheels were also just push fitted onto the axles as there are poly caps fitted inside the axles, the spare was fixed into place using 5 minute epoxy.Comment
I've been (Slowly) cracking on with the build, it's nearly there, just some bonnet catches to fit, plus the bonnet strap and the roof and wiper arms & blades, I've got the acrylic showcase on order for it ...Comment
Coming along nicely. The flocking looks great - it completely transforms the interior. I'd love to make this kit but it appears to be a bit scarce now. Saw one on eBay for ยฃ30 + another ยฃ30 postage from the USA or Taiwan!(
