Just caught up Simon some great work and coming along nicely.
SimonT - 1/24 Abandoned Mini
Looking at the dates it's been a while
Did a little more on this one yesterday
more damage inflicted - roof corner
The roof guttering also got the channel opened out with an Olfa P cutter as it is moulded without much of a channel
scuttle corner panel got rust holes - another typical rust spot
rear side windows got the frame flange added
rear valance corner rusted out
and the other corner
petrol tank filler cap positions drilled out
rear light mounting holes drilled out
A panel damage
holes for seatbelt reels opened out in rear companion boxes and boxes installed
spare wheel well rusted out
rear seat comes moulded with the rear parcel shelf so a bit of work was required with the Olfa cutter to separate the seat back without damaging it
the base squab was removed from the back in the same way
the parcel shelf was then extended and filled to add the bit lost by removal of the seat back
seat base will also require a bit of work to extend the back edge
A bit of progress but still a long way to goComment
[ATTACH]354935[/ATTACH]
[ATTACH]354936[/ATTACH]
[ATTACH]354937[/ATTACH]
[ATTACH]354938[/ATTACH]
A panel damage
[ATTACH]354939[/ATTACH]
[ATTACH]354940[/ATTACH]
[ATTACH]354941[/ATTACH]
Did you see the re run of the Mini Factory on BBC 4 last night . Fantastic insight to the way the new cars are built. Spoilt by James May showing just how little mechanical aptitude he really has , and silly jokes when they did links .Comment
Hi Simon
I too had forgotten this. Your Range Rover was stunning so this will be the same I'm sure. Excellent work so far and Minis were almost as good as Alfas and Ford Anglias at rusting so plenty of reference material :rolling: :anguished:
JimComment
Scottie - so had I ! :smiling5: Too many works in progress
Jim - oh yes, boy do they rust. My first car was a 1976 Clubman 1098cc - spent every weekend sanding down the rust and treating it with Jenolite rust convertor
Thanks Ian
Ken - thanks for dropping in, cheers
Further progress....
the dash panel comes with the instrument binnacle moulded in but since I am doing an abandoned project I wanted the binnacle separate
the only way to remove it without damage was to cut out the centre section of the dash, separate the binnacle from the piece of dash and then reassemble the dash
needs a little tidying up but should be fine
I realised I should have left the roof off to aid assembly and painting - too late, oops
sanded the scallop shape into the leading edge of the parcel shelf and then created the bulkhead that forms the seat back / front of the boot
this has the hole in it that was used at the factory to mount the early shells on a rotating spit
due to some wally sticking the roof on I had a right job trying to get the bulkhead / parcel shelf installed but after a few attempts I finally managed it
I then added a seat squab tray and the support bracket, again after a bit of a struggle due to limited space
the squab was boxed in with plastic card and filled
lastly the binnacle has been stuck to a sheet of plastic card - this will get trimmed down to create the flange that mounts it to the bulkheadComment
Jim - yes, a fair bit of modification required
Scottie - haha, don't know about that, all pretty standard stuff really so far
dash panel fitted to body shell
sanded down all the filler around the back seat / bulkhead - not the easiest thing to do due to lack of access
strengthening ribs then added to bulkhead from half round strip
also made a start on adding the lip of the boot aperture - kit boot lid not really removable so is missing a lot of detail
looking at this pic I noticed that the plastic is rather thick when looking through the rear light apertures - will have to try and thin this down
a rather fuzzy picture of the boot lid showing the internal structure made from plastic card, half round strip and all blended together with filler
the boot lid edges were all scraped to thin down the edges to a more scale like appearance
this took a lot longer to do than write about
I also cut out the instrument binnacle from the plastic card and formed the mounting flange then made the back of the instruments - forgot to take a picture thoughComment
