SimonT - 1/24 Abandoned Mini
Morning all,
did a bit of work on the mini engine
for some reason the main block is moulded with half of the cylinder head, the other half being a separate part that doesn't fit very well
sawed off the half head and joined it to the other kit part
it will need work
with the half head removed I could flatten off the top of the block and then modify it
I drilled out the cylinders, stud holes and water chamber holes
I had already stuck the two halves of the block together ages ago - hadn't considered that the engine is hollow so of course when I came to put the pistons in they just fell inside as there were no actual bores
Should have filled the parts before joining really but never mind - managed to use long bits of rod that run right down into the sump
CA'd some rod in to the head stud holes - they will need a little trimming to flatten off the endsComment
Obviously I wasn't around when you started this build but I've caught up from the start and there's some very impressive additions and modifications! Will make sure to keep an eye on this.Comment
Andy - thanks
Jim - fingers crossed
Si - thanks
Managed a bit more on this one
more rust around the headlight - another typical place
Done by bouncing the Dremel about with a grinding bit
created the bottom section of the B pillar - the kit is not intended to have open doors of course so a lot of structure is missing
inner sill / door step added along the bottom of the door aperture
rust added to base of window - yet another favourite of the tin worm
plus scuttle / windscreen corners and rear lower corners
in fact there isn't a lot that the tin worms won't chomp on
also continued adding the flanged edges around the windowsComment
Just caught up on this Simon, had to smile when I I read the Pistons fell through.
What I thought even Simon suffers from these sort of catastrophes:flushed::smiling2:.
Love the rust , like Jim mention bubbling up.
I still have some rust converter, not Jenolite but Curerust . Used it on a hanging baskets brkt and left it unpainted,looks fine even after 2 years .:smiling3:Comment
