SimonT - 1/24 Abandoned Mini
  • SimonT
    • 2824
    #91
    Morning all,
    bit more done on the bonnet last night
    said it was thinned right down - the internal bracing from the outside
    finished off the back corners
    added the anti burst catch from copper sheet - made same way as 1:1 from a folded piece of sheet, cut out then opened up
    the actual bonnet catch in the middle added from brass wire coil and a bit of rod with the end shaped
    side return flanges trimmed to shape
    actually this may be neater than real thing - some of mine had pronounced creases in them
    top side
    just hinge mounting brackets to do now
      • 15817
      Morning Simon
      That bonnet is great. Love the catch. Really looks down to scale thickness :thumb2:
      • SimonT
        • 2824
        #93
        Cheers Jim
        sorry about the crappy pic again - looked ok on the phone screen
        took me three attempts to get them right but I eventually got the bonnet mounting brackets sorted out
        each one is made from a single piece of copper sheet cut, folded and drilled
        I also put the chrome sprue into a lethal mixture of Dettol and oven cleaner
        within an hour the chrome plating had been eaten away leaving a nice shiny black sprue
        • BattleshipBob
          • 6821
          • Bob
          • Cardiff
          #94
          Cracking Simon
          Thats better made than a real one!!
          • Graeme C.
            • 1613
            • Graeme
            • UK
            #95
            Nice work on the bonnet Simon, it looks better than the new, heritage one on my nephews mini!
              • 15817
              Hi Simon
              What is your rechroming paint of choice? For a rusty wreck it probably won't warrant a really shiny chrome like paint.
              • Defiant911
                • Feb 2020
                • 640
                #97
                Fantastic work. Iโ€™d almost put rusty cars out of memory until this thread. my first few cars went rusty and they were not that old really, mk3 escorts and Vauxhallโ€™s cavaliers but thankfully modern Lexus donโ€™t seem to suffer that fate anymore. Looking forward to the final results.
                carl
                • Steve Jones
                  • 6615
                  #98
                  Nice to see you back on this one Mr T. The bonnet is outstanding!
                    That is looking amazing
                    • SimonT
                      • 2824
                      #100
                      Bob - build quality of real ones varies. I had one or two that were quite good but plenty that weren't :smiling5:
                      Graeme - :smiling5: thanks
                      Jim - in my experience the chrome tends to stay quite shiny, apart from dust/dirt, but you get micro spots of rust. Bumpers tended to rust from the inside. When really bad you were left with just a foil like thin layer of chrome - still shiny
                      I shall use one of those pens
                      Carl - cars in general are much better made these days. My Dad had Ford Cortina estates and Peugeot 504 estates in the 70's and they rusted faster than he could patch them
                      Cheers Steve
                      Thanks Ken
                      Spent most of yesterday on another build but did a little more late last night on this one
                      I created a separate rear sub frame off the car
                      the sub frame is supplied in bits plus the white rear bar is moulded to the underside of the boot floor - I removed that and hollowed it out in an early post
                      I hollowed out one of the solid brake backplates and added brake shoes, wheel cylinder, adjuster and a spring from 0.3mm copper wire wound around a 0.4mm drill bit
                      Need to make the hub next to fit in the centre
                      • scottie3158
                        • 14253
                        • Holbeach
                        #101
                        Simon that bonnet is outstanding mate.
                        • SimonT
                          • 2824
                          #102
                          Cheers Scottie
                          Did some more work on this - added the other shoe return spring then made the wheel hub with bolts which nicely covers up most of the internal detail :rolling:
                          Added a few bits to the sub frame to fill in missing bits of the kit pieces
                          Just found that I forgot to take pictures of it :smiling4:
                          • SimonT
                            • 2824
                            #103
ID:	1128435Click image for larger version
                            the photos I thought I had already taken.....
                              • 15817
                              Morning Simon
                              Up to your usual insanely good scratchery standards.
                              • SimonT
                                • 2824
                                #105
                                Thanks Jim - tried to thread the studs with my jewellers die but it wouldnโ€™t cut a decent thread so gave up and just used plain rod
