SimonT - 1/24 Abandoned Mini
...must try harder......so I did
thinking about it logically watchmakers, that these small tap and die sets are aimed at, don't work in plastic so I tried it with some brass wire instead
Success
Replaced the plastic studs with brass ones all having a threaded end section
the thread is 0.7mm - it is so fine it will probably vanish under paint :smiling5: oh well
while I was at it I also added the Schrader valves on the rear of the sub frame - these are used to pump in, or pump out, the hydrolastic suspension fluid (rather nice looking fluorescent green liquid) at great pressure
added the hydrolastic pipes that run from the Schrader valves into the hydro displacer units housed in the sub frame using 1mm lead wireComment
Thanks [COLOR=rgb(65, 168, 95)]Paul
Ian[/COLOR] - thank you, could have done with you marking my 'A' levels :smiling5:
[COLOR=rgb(65, 168, 95)]Neil[/COLOR] - you are more than welcome, thanks for following
[COLOR=rgb(65, 168, 95)]Scottie[/COLOR] - I've owned real ones that were nearly as rusty that still started :smiling5: Unfortunately the big bad MOT man refused to let me drive them for some reason:thinking:
[COLOR=rgb(65, 168, 95)]Jim[/COLOR] - thanks. Luckily, having owned a few over the years, I can still more remember what a lot of it should look like which helps
added the radius arm fixings last night - still need grease nipple adding
and the rear subframe mounting pins - looks like they will need a bit of tidying once the VJ filler sets!Comment
