Road Runner Hot Rod.
    Hi this is my next offering to the styrene god the Road Runner Hot Rod if you are going to build one of these there is a bit of flash but some of the seam lines are horrendous.
    (I hope you don't mind me building a cartoon car in this section.)
    Box art.
    Parts.
    Started with the air scoop by adding some missing casting lines, something like the one below.
    [ATTACH]326904[/ATTACH]
    Before.
    After.
    Next up is the exhaust down pipes which had very bad seam lines, removed the mouding between the two pipes using a piercing saw, added washer/nut to exh clamp.
    The orange block fits inside air intake manifold.
    The body bucket.
    Rear axel and tras spring wich I added nuts.
    The propshaft added some pivet pionts.
    All parts that need painting in primer.
    After looking at the model a bit closer I decided to make up some brake discs/callipers from spares box.
    Rear brake discs/callipers.
    Front brake discs/callipers.
    Thank you for looking in.
    Pete.
    Hi got all the painting done.
    Thank you for looking I hope you like what I've done.
    Will let it all dry for a few days.
    Pete.
    • spanner570
      • 15377
      Pete - Nice big, chunky parts. Great bit of relaxing therapy.
      I hope you are feeling a bit better.
      • Si Benson
        • 3572
        Good to see you still building Pete:thumb2:
          • 22769
          Cracking work Pete
            Hi Ron I'm enjoying this build apart from all the bad seam line,
            As for my health it a lot better thank you for asking, on three new drugs and is working very well, let's say it's what you would say it's have street value!!!! But it's not a clue it's just to help.
            Pete.
              Hi Si yes I'm still having a play.
              Pete.
                Originally posted by papa 695
                Cracking work Pete
                Hi Ian something a bit different for me please you like it.
                Pete.
                • Mini Me
                  • Jun 2018
                  • 10711
                  Roadrunner and Wile E.Coyote were my favorites as a kid. Kind of nice to flash back to simpler times. Thanks Pete for taking me back.
                  Cheers, RickH.
                    I love it! Pete...you have some talent for this toon kits :thumb2:
                      Cheers, RickH.
                      Cheers Rick glad you enjoyed the flash back, things seemed much simpler when were kids, happy days.
                      Pete.
                      • JR
                        • May 2015
                        • 18273
                        Polux you are quite right, he certainly has some talent. Bucket loads of it, and a tidy clean bench !
                        John.
                          Thank you kindly, 15% luck, 75% medication, 10% talent.
                          Pete.
                            John.
                            Hi John sorry I haven't been around I'm trying to get used to my new meds they seem to work but I keep forgetting to do things and it looks like I've got a lot of catching up on other people's builds.
                            Thank you for the very nice comment I'll have to reevaluate now 15% luck 75% medication 4% talent 1% bench tidying skill.
                            Pete.
                            • spanner570
                              • 15377
                              Pete.
                              Pete, luck, talent, bench tidying skill and medication will hopefully be the correct order for the above....... :thumb2:
                              Ron
