Revell 1/24 Ferrari Enzo
So I decided that I just couldn't leave the gap in the rear screen. After some thought I came up with a simple solution.
I cut the horizontal beam where it meets the bodywork with my razor saw, then glued the cut back together. The material removed by the width of the saw blade was enough to make the screen fit almost perfectly. I'm quite proud of that solution.
[ATTACH]340525[/ATTACH]Attached FilesSi vis pacem, para bellum.Comment
Nope, still can't see the join! Cracking bit of modification Bob.Comment
Got the interior finished today. The seats ended up a slightly different shade to each other, not sure why??
Also glued the front end of the body on and got it sanded flush.
[ATTACH]340684[/ATTACH][ATTACH]340685[/ATTACH][ATTACH]340686[/ATTACH][ATTACH]340687[/ATTACH][ATTACH]340688[/ATTACH]Si vis pacem, para bellum.Comment
