Great job. You could make this an ongoing project to return to when the mojo wanes, adding little bits/ideas as the mood strikes. PaulE
"Bendy Bus" VW Doka / 5th wheel camper kitbash
What a truly uplifting and inspirational build!
It's been a joy to follow, and even to have made a tiny contribution. Superb job Andy :thumb2:Comment
Andy............. well, what a turn up for the books, so well done, extreme scratchery at its best. Your attention to detail is exemplary. Top job. winner of the Race Towers Build of the month :thumb2::thumb2::thumb2::thumb2::thumb2::thumb2::t humb2:
Nice of Neil to send the scooter kit, top man .Comment
Thanks Neil, I'm so glad you enjoyed the build and the scooter makes a lovely addition.
And John, thanks, I'm honoured!Comment
Cheers Andy.
I'm not sure I'd agree with you given some of the amazing work going on around here, but thanks very much for the compliment :smiling3:Comment
Thanks Richard, I'm humbled to think you'd consider something of mine for inspiration!
Despite a couple of issues I really enjoyed this one though, so I'm sure to be doing more "custom" builds in the future, and have hopefully learnt a few lessons to make them even better.Comment
I'll start another thread in the correct place when I make a start on the diorama proper, but for now here's another accessory, a gazebo to shade our fella from the sun.
After a couple of false starts I first made up the square framework. I've scaled it roughly on my smaller one, around 8 feet square and just over 6 foot at the eaves. ~2.4m wide, ~ 1.9m high for you youngsters.
[ATTACH]405840[/ATTACH]
Then some 1mm wire was bent to start forming the legs and roof structure. Getting these to match was a mission!
[ATTACH]405841[/ATTACH]
Some 2mm tubing was slipped over the wire to give the legs a better scale thickness, and straighten them up a bit. The wire has been left slightly long so I can plant it into a base
[ATTACH]405842[/ATTACH]
And a couple of wet wipes soaked in PVA were used to make the cover. I'll trim the overhang to length once dry, and may even add a layer of tissue or two to stiffen it up and smooth it out a bit.
[ATTACH]405843[/ATTACH]Comment
And he's off!!...............Step right up folks Andy's at it again. Lovely start on your "Geebozo" sir...I'm absolutely blown away at the straight forward approach you employed in the construction of this less than solid structure. Well done.:smiling3:
Rick H.:thumb2:Comment
Thanks chaps.
I did try a couple of different methods Rick but they were all far too flimsy. The 3mm square tube is probably a bit over scale, equating to around 3" box section!, but since it's mostly hidden I think I'll get away with it.Comment
