Protar Porsche 956 1/24 Metal Body!
  • tigersteve
    • Jan 2018
    • 678
    I found this very old model bought from Italy on Ebay going cheap. Tatty box but complete - the decals have a little cracking on them but hopefully will go on OK . Not a lot of parts but its the overall finish I am looking for ...
    Now comes the 'interesting' part for me , not having played with metal before, I liked the idea of a bit of weight with the model .
    The main bodywork has a very small area where the doors will attach and it has broken in transit , don't think it will be a problem - what would be the best glue for this job ?
ID:	1126392Click image for larger version
ID:	1126393Click image for larger version
ID:	1126394Click image for larger version
ID:	1126395Click image for larger version
  • Nicko
    • Apr 2019
    • 1394
    • Nick
    • East Anglia
    I wonder if it might be better to try and solder it back together....
    Nick.
      • 18880
      If it solders, I would agree with Nick. However, if it’s Mazak or similar (dinky toy type metal) it won’t soft solder, so I would recommend two part epoxy followed by cellulose filler to smooth out the joint. The glue lands look quite small so anything else like superglue will probably fracture during assembly.
      • tigersteve
        • Jan 2018
        • 678
        Thanks for both suggestions - I'm going with the two part epoxy........
          • 18880
          Good man. You’ll need something like blu tac to support the join while the glue dries.....
          • tigersteve
            • Jan 2018
            • 678
ID:	1130604Click image for larger version
ID:	1130605Click image for larger version
            A little progress, but a long way to go to make this look half decent !
              • 18880
              Starting to come together Steve. Did the epoxy work OK?
                • 22769
                Just seen this one Steve, and a cracking start and fix.
                • tigersteve
                  • Jan 2018
                  • 678
                  There has been quite a delay as I had to buy new decals from Italy as the old ones were beyond saving ( I did have a play with them ! ) The originals were designed to be applied to an all white body but the new ones require blue painted sides etc.
                  The epoxy worked fine and all was well with a nice coat of primer then white all over ( spray can and brush only )
                  polished again and en route to the spray booth ( garden shed and rattle can ) when disaster struck as I managed to drop it from waist height onto a concrete path ..........
                  At which point the bonnet and side panels parted company with the body !!
                  Oh how I laughed as I had to reattach what looked like the perfect original into a not quite so good second try .
                  Now got a couple of coats of blue on and will mask up and hopefully make a better fist of the paint , eventually...
ID:	1130633Click image for larger version
ID:	1130634Click image for larger version
                  • tigersteve
                    • Jan 2018
                    • 678
                    Well after a delay of 4 months the Porsche is just about done. I travel a lot and have been away in France since August but now finally got round to it again ! The mirrors and windscreen wiper are all thats left to do, but they will have to wait till I am back in France where the car remains. It has been interesting working with the metal bodywork which adds a nice weight to the model .
                    Now for a bit of Quarantining :sick::thumb2:
ID:	1138767Click image for larger version
ID:	1138768Click image for larger version
ID:	1138769Click image for larger version
                      • 18880
                      That’s really good. Can’t see the joins at all, which is a tribute to your workmanship.
                        Superb
