Revell 1/24 Ferrari F 310B 1997 Formula 1
DaveComment
Just about ready to fit the upper body & say goodbye to the engine!
It pays to read the instructions, several decals have to be added before assembly ( like the internal faces of the rear wing - carbon fibre decals to be added ), and the seatbelts - luckily the seat tub is still loose............
DaveComment
Next problem will be adding decals to those 'rubber' tyres
I have been having a go at the tyre decals I have tried a few different ways but it looks like they just go on the tyre in the normal way (mine did) I will find out in the morning when they are dry.Comment
DaveComment
Just found out that putting decals on the tyres didn't work as once dried they fall off but if you put a bit of varnish on they stick.Comment
Never tried tyre decals (yet). Do they dry with bad silvering? Just wondering because the surface of the rubber is quite rough in relation to a paint finish?Comment
After a bit of wriggling, top & bottom joined - although, I lost one of the radiators - which I find is almost impossible to spot, without a borescope!
I've roughly sanded the tyres, after fitting the painted hubs, a little more needed to remove the joint line & dry fitted to see if they touch the ground ( they do! ). The front & rear wings can be assembled & decalled off the model. There are quite a few decals, so I'll do them in several sittings, largest first, maybe leaving them overnight before going onto the small ones. The front wheel hubs steer, but I'm going to fix them in a straight line - they've fallen off so many times & the track rod has taken a positive dislike to being confined!
DaveComment
And so the decals start......................
I did a thin coat of gloss varnish on the rims of the tyres last night & added the decals this morning - I used decal solution - to avoid any silvering - looks OK so far. I did the insides of the tyres first, so any process errors won't show too much! - I may give a satin varnish over the tyre walls, haven't decided yet.
The Revell decals are rather thick, and need persuasion with cotton buds & decal solution to sit down, I can see this being a slow process!
DaveComment
